Datasheet MMDF2C03HDR2G - ON Semiconductor Даташит Полевой транзистор, NP — Даташит
Наименование модели: MMDF2C03HDR2G
![]() 19 предложений от 15 поставщиков Mosfet Array 30V 4.1A, 3A 2W Surface Mount 8-SOIC | |||
MMDF2C03HDR2G Rochester Electronics | 45 ₽ | ||
MMDF2C03HDR2G ON Semiconductor | 465 ₽ | ||
MMDF2C03HDR2G ON Semiconductor | по запросу | ||
Производитель: ON Semiconductor
Описание: Полевой транзистор, NP
MMDF2C03HD
Preferred Device
Power MOSFET 2 Amps, 30 Volts
Complementary SO-8, Dual
These miniature surface mount MOSFETs feature ultra low RDS(on) and true logic level performance.
They are capable of withstanding high energy in the avalanche and commutation modes and the drain-to-source diode has a very low reverse recovery time. MiniMOSt devices are designed for use in low voltage, high speed switching applications where power efficiency is important. Typical applications are dc-dc converters, and power management in portable and battery powered products such as computers, printers, cellular and cordless phones. They can also be used for low voltage motor controls in mass storage products such as disk drives and tape drives. The avalanche energy is specified to eliminate the guesswork in designs where inductive loads are switched and offer additional safety margin against unexpected voltage transients.
- Полярность транзистора: N and P Channel
- Drain Source Voltage Vds: 30 В
- Voltage Vgs Max: 1.7 В
- Корпус транзистора: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Cont Current Id N Channel: 4.1 А
- Cont Current Id P Channel: 3 А
- Current Id Max: 4.1 А
- On State Resistance @ Vgs = 10V N Channel: 60 МОм
- On State Resistance @ Vgs = 10V P Channel: 70 МОм
- On State Resistance @ Vgs = 4.5V N Channel: 65 МОм
- On State Resistance @ Vgs = 4.5V P Channel: 225 МОм
- Тип корпуса: SOIC-8
- Power Dissipation Pd: 2 Вт
- Pulse Current Idm N Channel: 21 А
- Pulse Current Idm P Channel: 15 А
- Способ монтажа: SMD
- Voltage Vds Typ: 30 В
- Voltage Vgs th P Channel Max: 2 В
- Voltage Vgs th P Channel Min: 1 В
Дополнительные аксессуары:
- Roth Elektronik - RE932-01
