Datasheet STY60NM60 - STMicroelectronics Даташит Полевой транзистор N CH 600 В 60 А MAX247 — Даташит
STMicroelectronics STY60NM60
Наименование модели: STY60NM60
31 предложений от 20 поставщиков
MOSFET N-CH 600V 60A MAX247. N-Channel 600V 60A (Tc) 560W (Tc) Through Hole MAX247TM. Transistors - FETs, MOSFETs - Single...
STY60NM60
от 417 ₽
Рутоника
STY60NM60
1 108 ₽
Зенер
Россия и страны ТС
STY60NM60
от 2 717 ₽
Microfind
STY60NM60
4 526 ₽
Описание: Полевой транзистор N CH 600 В 60 А MAX247
data sheetСкачать Data Sheet
STY60NM60
N-CHANNEL 600V - 0.050 - 60A Max247 Zener-Protected MDmeshTMPower MOSFET
TYPE STY60NM60 VDSS 600V RDS(on) < 0.055 ID 60 A
TYPICAL RDS(on) = 0.050 HIGH dv/dt AND AVALANCHE CAPABILITIES IMPROVED ESD CAPABILITY LOW INPUT CAPACITANCE AND GATE CHARGE LOW GATE INPUT RESISTANCE TIGHT PROCESS CONTROL INDUSTRY'S LOWEST ON-RESISTANCE DESCRIPTION The MDmeshTM is a new revolutionary MOSFET technology that associates the Multiple Drain process with the Company's PowerMESHTM horizontal layout.
The resulting product has an outstanding low on-resistance, impressively high dv/dt and excellent avalanche characteristics. The adoption of the Company's proprietary strip technique yields overall dynamic performance that is significantly better than that of similar competition's products. APPLICATIONS The MDmeshTM family is very suitable for increasing power density of high voltage converters allowing system miniaturization and higher efficiencies.
2 1
  • Continuous Drain Current Id: 30 А
  • Drain Source Voltage Vds: 600 В
  • On State Resistance: 50 МОм
  • Rds(on) Test Voltage Vgs: 30 В
  • Voltage Vgs Max: 4 В
  • Рабочий диапазон температрур: -65°C ... +150°C
  • Корпус транзистора: MAX-247
  • Количество выводов: 3
  • SVHC: No SVHC (15-Dec-2010)
  • Current Id Max: 60 А
  • Тип корпуса: Max-247
  • Power Dissipation Pd: 560 Вт
  • Threshold Voltage Vgs Typ: 4 В
  • Тип транзистора: Power MOSFET
  • Voltage Vds Typ: 600 В
  • Voltage Vgs Rds on Measurement: 10 В
На английском языке: Datasheet STY60NM60 - STMicroelectronics MOSFET N CH 600 V 60 A MAX247
