Datasheet SQD30N05-20L -GE3 - Vishay Даташит Полевой транзистор, N CH, Вт диод, 55 В, 30 А, TO-252 — Даташит
Vishay SQD30N05-20L -GE3
Наименование модели: SQD30N05-20L -GE3
40 предложений от 14 поставщиков
SQD30N05-20L_GE3
27 ₽
SQD30N05-20L_GE3
от 175 ₽
727GS
SQD30N05-20L-GE3
Hi-Tech Circuit Group
SQD30N05-20L_GE3
Производитель: Vishay
Описание: Полевой транзистор, N CH, Вт диод, 55 В, 30 А, TO-252
data sheetСкачать Data Sheet
SPICE Device Model SQD30N05-20L
Vishay Siliconix
N-Channel 55 V (D-S) 175 °C MOSFET
DESCRIPTION
The attached SPICE model describes the typical electrical characteristics of the n-channel vertical DMOS.
The subcircuit model is extracted and optimized over the - 55 °C to + 125 °C temperature ranges under the pulsed 0 V to 10 V gate drive. The saturated output impedance is best fit at the gate bias near the threshold voltage. A novel gate-to-drain feedback capacitance network is used to model the gate charge characteristics while avoiding convergence difficulties of the switched Cgd model. All model parameter values are optimized to provide a best fit to the measured electrical data and are not intended as an exact physical interpretation of the device.
  • Continuous Drain Current Id: 30 А
  • Drain Source Voltage Vds: 55 В
  • On State Resistance: 0.016 Ом
  • Voltage Vgs Max: 5 В
  • Рабочий диапазон температрур: -55°C ... +175°C
  • Корпус транзистора: TO-252
  • Количество выводов: 3
SQD30N0520L GE3, SQD30N05 20L GE3
На английском языке: Datasheet SQD30N05-20L -GE3 - Vishay MOSFET, N CH, W DIODE, 55 V, 30 A, TO-252
