Datasheet FDC6303N - Fairchild Даташит Полевой транзистор, сдвоенный, N, SMD, SUPERSOT-6 — Даташит
Fairchild FDC6303N
Наименование модели: FDC6303N
44 предложений от 18 поставщиков
Дискретные полупроводники Транзисторы — полевые — массивы
FDC6303N
от 32 ₽
FDC6303N
от 36 ₽
FDC6303N
38 ₽
FDC6303N_NL
Fairchild
Производитель: Fairchild
Описание: Полевой транзистор, сдвоенный, N, SMD, SUPERSOT-6
data sheetСкачать Data Sheet
August 1997
FDC6303N Digital FET, Dual N-Channel
General Description
These dual N-Channel logic level enhancement mode field effect transistors are produced using Fairchild's proprietary, high cell density, DMOS technology.
This very high density process is especially tailored to minimize on-state resistance. This device has been designed especially for low voltage applications as a replacement for digital transistors in load switching applications. Since bias resistors are not required this one N-Channel FET can replace several digital transistors with different bias resistors like the IMHxA series.
Features
  • Module Configuration: Dual
  • Continuous Drain Current Id: 680 мА
  • Drain Source Voltage Vds: 25 В
  • On Resistance Rds(on): 450 МОм
  • Rds(on) Test Voltage Vgs: 4.5 В
  • Threshold Voltage Vgs Typ: 800 мВ
  • Power Dissipation Pd: 900 мВт
  • Корпус транзистора: SuperSOT
  • Количество выводов: 6
  • SVHC: No SVHC (15-Dec-2010)
  • Current Id Max: 680 мА
  • Тип корпуса: SuperSOT-6
  • Способ монтажа: SMD
  • Voltage Vds Typ: 25 В
  • Voltage Vgs Max: 800 мВ
  • Voltage Vgs Rds on Measurement: 4.5 В
На английском языке: Datasheet FDC6303N - Fairchild MOSFET, DUAL, N, SMD, SUPERSOT-6
