Datasheet FDC6320C - Fairchild Даташит Полевой транзистор, NP — Даташит
Наименование модели: FDC6320C
![]() 21 предложений от 20 поставщиков Дискретные полупроводники Транзисторы — полевые — массивы | |||
FDC6320C Fairchild | 30 ₽ | ||
FDC6320C ON Semiconductor | 58 ₽ | ||
FDC6320C_NL Fairchild | по запросу | ||
Производитель: Fairchild
Описание: Полевой транзистор, NP
October 1997
FDC6320C Dual N & P Channel , Digital FET
General Description
These dual N & P Channel logic level enhancement mode field effec transistors are produced using Fairchild's proprietary, high cell density, DMOS technology.
This very high density process is especially tailored to minimize on-state resistance. The device is an improved design especially for low voltage applications as a replacement for bipolar digital transistors in load switching applications. Since bias resistors are not required, this dual digital FET can replace several digital transistors with difference bias resistors.
Features
- Полярность транзистора: N and P Channel
- Rds(on) Test Voltage Vgs: 2.7 В
- Рассеиваемая мощность: 900 мВт
- Корпус транзистора: SuperSOT
- Количество выводов: 6
- SVHC: No SVHC (20-Jun-2011)
- Cont Current Id N Channel: 0.22 А
- Cont Current Id P Channel: 120 мА
- Continuous Drain Current Id: 220 мА
- Current Id Max: 220 мА
- Drain Source Voltage Vds: 25 В
- Module Configuration: Dual
- On Resistance Rds(on): 5 Ом
- On State Resistance N Channel Max: 4 Ом
- On State Resistance P Channel Max: 10 Ом
- Тип корпуса: SuperSOT-6
- Способ монтажа: SMD
- Voltage Vds Typ: 25 В
- Voltage Vgs Max: 850 мВ
- Voltage Vgs Rds N Channel: 4.5 В
- Voltage Vgs Rds P Channel: 4.5 В
- Voltage Vgs Rds on Measurement: 4.5 В
- Voltage Vgs th N Channel 1 Min: 0.65 В
- Voltage Vgs th P Channel Max: -1.5 В
- Voltage Vgs th P Channel Min: -0.65 В
