Datasheet FDC6561AN - Fairchild Даташит Полевой транзистор, сдвоенный, NN, SUPERSOT-6 — Даташит
Fairchild FDC6561AN
Наименование модели: FDC6561AN
37 предложений от 20 поставщиков
Двойной МОП-транзистор, N Канал, 30 В, 2.5 А, 0.082 Ом, SuperSOT, Surface Mount
FDC6561AN
от 6.16 ₽
Элитан
FDC6561AN
37 ₽
FDC6561AN
53 ₽
FDC6561AN651
Fairchild
Производитель: Fairchild
Описание: Полевой транзистор, сдвоенный, NN, SUPERSOT-6
data sheetСкачать Data Sheet
April 1999
FDC6561AN Dual N-Channel Logic Level PowerTrenchTM MOSFET
General Description Features
2.5 A, 30 V.
RDS(ON) = 0.095 @ VGS = 10 V RDS(ON) = 0.145 @ VGS = 4.5 V Very fast switching. Low gate charge (2.1nC typical). SuperSOTTM-6 package: small footprint (72% smaller than standard SO-8); low profile (1mm thick).
These N-Channel Logic Level MOSFETs are produced using Fairchild Semiconductor's advanced PowerTrench process that has been especially tailored to minimize the on-state resistance and yet maintain low gate charge for superior switching performance. These devices are well suited for all applications where small size is desireable but especially low cost DC/DC conversion in battery powered systems.
  • Module Configuration: Dual
  • Continuous Drain Current Id: 2.5 А
  • Drain Source Voltage Vds: 30 В
  • On Resistance Rds(on): 95 МОм
  • Threshold Voltage Vgs Typ: 1.8 В
  • Power Dissipation Pd: 960 мВт
  • Корпус транзистора: SuperSOT
  • Количество выводов: 6
  • SVHC: No SVHC (15-Dec-2010)
  • Current Id Max: 2.5 А
  • Количество транзисторов: 2
  • Тип корпуса: SuperSOT-6
  • Способ монтажа: SMD
  • Current Temperature: 25°C
  • Pulse Current Idm: 10 А
  • SMD Marking: FDC6561AN
  • Uni / Bi Directional Polarity: NN
  • Voltage Vds: 30 В
  • Voltage Vds Typ: 30 В
  • Voltage Vgs Max: 1.8 В
  • Voltage Vgs Rds on Measurement: 10 В
  • Voltage Vgs th Max: 3 В
На английском языке: Datasheet FDC6561AN - Fairchild MOSFET, DUAL, NN, SUPERSOT-6
