Datasheet FDG6301N - Fairchild Даташит Полевой транзистор, сдвоенный, N, SMD, 6-SC-70 — Даташит
Fairchild FDG6301N
Наименование модели: FDG6301N
43 предложений от 23 поставщиков
MOSFET 2N-CH 25V 0.22A SC70-6. Mosfet Array 2 N-Channel (Dual) 25V 220mA 300mW Surface Mount SC-88 (SC-70-6). Transistors - FETs, MOSFETs...
FDG6301N
от 4.13 ₽
FDG6301N_NL
Fairchild
МосЧип
FDG6301N
Fairchild
FDG6301N
Производитель: Fairchild
Описание: Полевой транзистор, сдвоенный, N, SMD, 6-SC-70
data sheetСкачать Data Sheet
July 1999
FDG6301N Dual N-Channel, Digital FET
General Description
These dual N-Channel logic level enhancement mode field effect transistors are produced using Fairchild's proprietary, high cell density, DMOS technology.
This very high density process is especially tailored to minimize on-state resistance. This device has been designed especially for low voltage applications as a replacement for bipolar digital transistors and small signal MOSFETs.
Features
  • Continuous Drain Current Id: 220 мА
  • Drain Source Voltage Vds: 25 В
  • On Resistance Rds(on): 4 Ом
  • Rds(on) Test Voltage Vgs: 4.5 В
  • Threshold Voltage Vgs Typ: 850 мВ
  • Рассеиваемая мощность: 300 мВт
  • Корпус транзистора: SC-70
  • Количество выводов: 6
  • SVHC: No SVHC (19-Dec-2011)
  • Continuous Drain Current Id, N Channel: 220 мА
  • Current Id Max: 220 мА
  • Drain Source Voltage Vds, N Channel: 25 В
  • Module Configuration: Dual
  • On Resistance Rds(on), N Channel: 2.6 Ом
  • Тип корпуса: SC-70
  • Способ монтажа: SMD
  • Voltage Vds Typ: 25 В
  • Voltage Vgs Max: 850 мВ
  • Voltage Vgs Rds on Measurement: 4.5 В
На английском языке: Datasheet FDG6301N - Fairchild MOSFET, DUAL, N, SMD, 6-SC-70
