Datasheet NDS8958 - Fairchild Даташит Полевой транзистор, сдвоенный, NP, SO-8 — Даташит
Fairchild NDS8958
Наименование модели: NDS8958
Транзисторы - Двойные МОП-транзисторы
NDS8958
Fairchild
от 515 ₽
727GS
NDS8958NL
МосЧип
NDS8958A
Fairchild
NDS8958-NL
Производитель: Fairchild
Описание: Полевой транзистор, сдвоенный, NP, SO-8
data sheetСкачать Data Sheet
July 1996
NDS8958 Dual N & P-Channel Enhancement Mode Field Effect Transistor
General Description
These dual N- and P-Channel enhancement mode power field effect transistors are produced using Fairchild's proprietary, high cell density, DMOS technology.
This very high density process is especially tailored to minimize on-state resistance and provide superior switching performance. These devices are particularly suited for low voltage applications such as notebook computer power management and other battery powered circuits where fast switching, low in-line power loss, and resistance to transients are needed.
Features
  • Module Configuration: Dual
  • Полярность транзистора: N and P Channel
  • Continuous Drain Current Id: 4 А
  • Drain Source Voltage Vds: 30 В
  • On Resistance Rds(on): 65 МОм
  • Threshold Voltage Vgs Typ: 1.6 В
  • Power Dissipation Pd: 2 Вт
  • Рабочий диапазон температрур: -55°C ... +150°C
  • Корпус транзистора: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Current Id Max: 5.3 А
  • Количество транзисторов: 2
  • Тип корпуса: SOIC
  • Способ монтажа: SMD
  • Cont Current Id N Channel 2: 5.3 А
  • Cont Current Id P Channel: 4 А
  • Current Temperature: 25°C
  • On State Resistance Channel 1: 50 МОм
  • On State Resistance P Channel 2: 100 МОм
  • Power Dissipation N Channel 2: 2 Вт
  • Power Dissipation P Channel 2: 2 Вт
  • Pulse Current Idm: 15 А
  • Pulse Current Idm N Channel 2: 20 А
  • Pulse Current Idm P Channel: 15 А
  • SMD Marking: NDS8958
  • Voltage Vds: 30 В
  • Voltage Vds N Channel 1: 30 В
  • Voltage Vds P Channel 1: 30 В
  • Voltage Vds Typ: 30 В
  • Voltage Vgs Max: 20 В
Дополнительные аксессуары:
  • Dow Corning - 2265931
  • Fischer Elektronik - ICK SMD A 5 SA
  • Fischer Elektronik - WLK 5
На английском языке: Datasheet NDS8958 - Fairchild MOSFET, DUAL, NP, SO-8
