Datasheet HFA3128BZ - Intersil Даташит ИС транзистор ARRAY, ULTRA H FREQ — Даташит
Наименование модели: HFA3128BZ
![]() 16 предложений от 13 поставщиков Двухполюсный плоскостной транзистор, SOIC PNP 8V 0.065A | |||
HFA3128BZ Intersil | 141 ₽ | ||
HFA3128BZ Intersil | 152 ₽ | ||
HFA3128BZ Intersil | от 215 ₽ |
Производитель: Intersil
Описание: ИС транзистор ARRAY, ULTRA H FREQ
HFA3046, HFA3096, HFA3127, HFA3128
Data Sheet December 21, 2005 FN3076.13
Ultra High Frequency Transistor Arrays
The HFA3046, HFA3096, HFA3127 and the HFA3128 are Ultra High Frequency Transistor Arrays that are fabricated from Intersil Corporation's complementary bipolar UHF-1 process.
Each array consists of five dielectrically isolated transistors on a common monolithic substrate. The NPN transistors exhibit a fT of 8GHz while the PNP transistors provide a fT of 5.5GHz. Both types exhibit low noise (3.5dB), making them ideal for high frequency amplifier and mixer applications. The HFA3046 and HFA3127 are all NPN arrays while the HFA3128 has all PNP transistors. The HFA3096 is an NPN-PNP combination. Access is provided to each of the terminals for the individual transistors for maximum application flexibility. Monolithic construction of these transistor arrays provides close electrical and thermal matching of the five transistors. Intersil provides an Application Note illustrating
- Module Configuration: Five
- Полярность транзистора: PNP
- Collector Emitter Voltage V(br)ceo: 12 В
- Power Dissipation Pd: 150 мВт
- DC Collector Current: 37 мА
- DC Current Gain: 60
- Рабочий диапазон температрур: -55°C ... +125°C
- Корпус транзистора: SOIC
- Количество выводов: 16
- SVHC: No SVHC (15-Dec-2010)
- Частота единичного усиления типовая: 5.5 ГГц
- Количество транзисторов: 5
- Тип корпуса: SOIC
- Способ монтажа: SMD
- Семейство: 3128
- Current Ic Continuous a Max: 34 мА
- Количество каналов: 5
Дополнительные аксессуары:
- BONKOTE - BON102
- Electrolube - SMA10SL
- Roth Elektronik - RE932-04
