Datasheet MC1413BDG - ON Semiconductor Даташит Транзистор ARRAY — Даташит
Наименование модели: MC1413BDG
Производитель: ON Semiconductor
Описание: Транзистор ARRAY
MC1413, MC1413B, NCV1413B High Voltage, High Current Darlington Transistor Arrays
The seven NPN Darlington connected transistors in these arrays are well suited for driving lamps, relays, or printer hammers in a variety of industrial and consumer applications.
Their high breakdown voltage and internal suppression diodes insure freedom from problems associated with inductive loads. Peak inrush currents to 500 mA permit them to drive incandescent lamps. The MC1413, B with a 2.7 kW series input resistor is well suited for systems utilizing a 5.0 V TTL or CMOS Logic.
Features http://onsemi.com
16 1
PDIP-16 P SUFFIX CASE 648
- Module Configuration: Seven
- Полярность транзистора: NPN
- Collector Emitter Voltage V(br)ceo: 50 В
- DC Collector Current: 500 мА
- DC Current Gain: 1000
- Рабочий диапазон температрур: -40°C ... +85°C
- Корпус транзистора: SOIC
- Количество выводов: 16
- SVHC: No SVHC (15-Dec-2010)
- Количество транзисторов: 7
- Тип корпуса: 16-SOIC
- Способ монтажа: SMD
- Current Ic Continuous a Max: 500 мА
Дополнительные аксессуары:
- Electrolube - HTS35SL
- Fischer Elektronik - ICK SMD A 8 SA
- Roth Elektronik - RE932-04
- STANNOL - 631954
