Datasheet NTE912 - NTE Electronics Даташит Транзистор ARRAY, NPN — Даташит
Наименование модели: NTE912
![]() 12 предложений от 8 поставщиков Integrated Circuit General Purpose Transistor Array (Three Isolated Transistors and One Differentially-Connected Transistor Pair) | |||
NTE912 NTE Electronics | 405 ₽ | ||
NTE912 NTE Electronics | 575 ₽ | ||
NTE912 | по запросу |
Производитель: NTE Electronics
Описание: Транзистор ARRAY, NPN
NTE912 Integrated Circuit General Purpose Transistor Array
(Three Isolated Transistors and One DifferentiallyConnected Transistor Pair) Description: The NTE912 consists of five generalpurpose silicon NPN transistors on a common monolithic substrate in a 14Lead DIP type package.
Two of the transistors are internally connected to form a differentiallyconnected pair. The transistors of the NTE912 are well suited to a wide variety of applications in low power systems in the DC through VHF range. They may be used as discrete transistors in conventional circuits. However, in addition, they provide the very significant inherent integrated circuit advantages of close electrical and thermal matching. Features: D Two Matched Pairs of Transistors: VBE matched ±5mV Input Offset Current 2µA Max. @ IC = 1mA D 5 General Purpose Monolithic Transistors D Operation from DC to 120MHz D Wide Operating Current Range D Low Noise Figure: 3.2dB Typ @ 1kHz Applications: D General Use In All Types of Signal
- Module Configuration: Five
- Полярность транзистора: NPN
- Collector Emitter Voltage V(br)ceo: 24 В
- Power Dissipation Pd: 750 мВт
- DC Collector Current: 50 мА
- DC Current Gain: 100
- Рабочий диапазон температрур: -55°C ... +125°C
- Корпус транзистора: DIP
- Количество выводов: 14
- SVHC: No SVHC (15-Dec-2010)
- Маркировка: NTE912
- Частота единичного усиления типовая: 550 МГц
- Количество транзисторов: 3
- Тип корпуса: DIP
- Способ монтажа: Radial Leaded
- Current Ic Continuous a Max: 50 мА
Дополнительные аксессуары:
- Multicomp - 2227MC-14-03-10-F1
