Datasheet Texas Instruments ULN2803ADW — Даташит
СерияULN2803A
МодельULN2803ADW
Транзисторная матрица Дарлингтона 18-SOIC от -40 до 85
ULN2803A Darlington Transistor Arrays datasheet
PDF, 989 Кб, Версия: H, Файл опубликован: 14 фев 2017
TRANS 8NPN DARL 50V 0.5A 18SO. Bipolar (BJT) Transistor Array 8 NPN Darlington 50V 500mA Surface Mount 18-SOIC. Transistors - Bipolar...
Microfind
ULN2803ADW
218 ₽
Элитан
ULN2803ADW
226 ₽
Hi-Tech Circuit Group
ULN2803ADW-P
ULN2803ADW
Pin18
Package TypeDW
Package QTY40
МаркировкаULN2803A
Width (мм)7.5
Length (мм)11.5
Thickness (мм)2.35
Max Height (мм)2.65
Delay Time(Typ)130 нс
Drivers Per Package8
Input CompatibilityCMOS,TTL
Iout/ch(Max)500 мА
Iout_off(Typ)50 uA
Output Voltage(Max)50 В
Package Size: mm2:W x L18SOIC: 119 mm2: 10.3 x 11.55(SOIC) PKG
Peak Output Current500 мА
Switching Voltage(Max)50 В
Vol@Lowest Spec Current(Typ)900 мВ
  • Evaluation Modules & Boards: BOOSTXL-ULN2003
    Dual Stepper Motor Driver BoosterPack featuring ULN2003 and CSD17571Q2 NexFETВ™
  • Improved Thermal Dissipation and Energy Efficiency for Peripheral Driving
    PDF, 330 Кб, Файл опубликован: 30 окт 2014
  • Stepper Motor Driving with Peripheral Drivers (Rev. A)
    PDF, 172 Кб, Версия: A, Файл опубликован: 2 дек 2016
    This application report describes in detail how to interface stepper motors with TI peripheral drivers. Primarily, this report discusses how to connect and drive stepper motors, including the stepper motor driving patterns. Advantages and disadvantages to each stepping pattern are discussed; and logic tables, timing diagrams, and pictorial representations of each driving pattern are provided.
  • Semiconductors > Power Management > Peripheral Driver and Actuator
На английском языке: Datasheet Texas Instruments ULN2803ADW
