Datasheet MUN5211DW1T1G - ON Semiconductor Даташит BRT транзистор, 50 В, 10K/10KOHM, SOT-363 — Даташит
ON Semiconductor MUN5211DW1T1G
Наименование модели: MUN5211DW1T1G
64 предложений от 24 поставщиков
TRANS 2NPN PREBIAS 0.25W SOT363. Pre-Biased Bipolar Transistor (BJT) 2 NPN - Pre-Biased (Dual) 50V 100mA 250mW Surface Mount SC-88/SC70-6/SOT-363. Transistors...
MUN5211DW1T1G
от 1.22 ₽
Microfind
MUN5211DW1T1G
от 2.52 ₽
Контест
MUN5211DW1T1G
14 ₽
MUN5211DW1T1G
Производитель: ON Semiconductor
Описание: BRT транзистор, 50 В, 10K/10KOHM, SOT-363
data sheetСкачать Data Sheet
MUN5211DW1T1G Series
Preferred Devices
Dual Bias Resistor Transistors
NPN Silicon Surface Mount Transistors with Monolithic Bias Resistor Network
The Bias Resistor Transistor (BRT) contains a single transistor with a monolithic bias network consisting of two resistors; a series base resistor and a base-emitter resistor.
These digital transistors are designed to replace a single device and its external resistor bias network. The BRT eliminates these individual components by integrating them into a single device. In the MUN5211DW1T1G series, two BRT devices are housed in the SOT-363 package which is ideal for low power surface mount applications where board space is at a premium.
  • Полярность транзистора: NPN
  • Collector Emitter Voltage V(br)ceo: 50 В
  • Power Dissipation Pd: 385 мВт
  • DC Collector Current: 100 мА
  • DC Current Gain Max (hfe): 60
На английском языке: Datasheet MUN5211DW1T1G - ON Semiconductor BRT TRANSISTOR, 50 V, 10K/10KOHM, SOT-363
