Datasheet MUN5311DW1T1G - ON Semiconductor Даташит BRT транзистор, 50 В, 10K/10KOHM, SC88 — Даташит
ON Semiconductor MUN5311DW1T1G
Наименование модели: MUN5311DW1T1G
61 предложений от 23 поставщиков
TRANS PREBIAS NPN/PNP SOT363. Pre-Biased Bipolar Transistor (BJT) 1 NPN, 1 PNP - Pre-Biased (Dual) 50V 100mA 250mW Surface Mount SC-88/SC70-6/SOT-363....
ICdarom.ru
MUN5311DW1T1G ONS SOT363-6
от 3.18 ₽
MUN5311DW1T1G
от 8.08 ₽
727GS
MUN5311DW1T1G
MUN5311DW1T1G
Производитель: ON Semiconductor
Описание: BRT транзистор, 50 В, 10K/10KOHM, SC88
data sheetСкачать Data Sheet
MUN5311DW1T1G Series Dual Bias Resistor Transistors
Preferred Devices
NPN and PNP Silicon Surface Mount Transistors with Monolithic Bias Resistor Network
The Bias Resistor Transistor (BRT) contains a single transistor with a monolithic bias network consisting of two resistors; a series base resistor and a base-emitter resistor.
These digital transistors are designed to replace a single device and its external resistor bias network. The BRT eliminates these individual components by integrating them into a single device. In the MUN5311DW1T1G series, two complementary BRT devices are housed in the SOT-363 package which is ideal for low power surface mount applications where board space is at a premium.
Features
  • Полярность транзистора: NPN & PNP
  • Collector Emitter Voltage V(br)ceo: 50 В
  • Power Dissipation Pd: 256 мВт
  • DC Collector Current: 100 мА
  • DC Current Gain: 60
  • Рабочий диапазон температрур: -55°C ... +150°C
На английском языке: Datasheet MUN5311DW1T1G - ON Semiconductor BRT TRANSISTOR, 50 V, 10K/10KOHM, SC88
