Datasheet NTE2013 - NTE Electronics Даташит DARLINGTON ARRAY, NPN, 7, 50 В, DIP — Даташит
NTE Electronics NTE2013
Наименование модели: NTE2013
8 предложений от 7 поставщиков
транзистор характеристики, DIP NPN 50V 0.5A
NTE2013
NTE Electronics
338 ₽
NTE2013
NTE Electronics
от 775 ₽
Элитан
NTE2013
NTE Electronics
15 400 ₽
МосЧип
NTE-2013
Производитель: NTE Electronics
Описание: DARLINGTON ARRAY, NPN, 7, 50 В, DIP
data sheetСкачать Data Sheet
NTE2011/NTE2012/NTE2013/NTE2014/NTE2015 Integrated Circuit 7-Channel Darlington Array/Driver
Description: The NTE2011 through NTE2015 are high-voltage, high-current Darlington arrays in a 16-Lead DIP type package and are comprised of seven silicon NPN Darlington pairs on a common monolithic substrate.
All units have open-collector outputs and integral diodes for inductive load transient suppression. Peak inrush currents to 600mA (NTE2011, NTE2013, NTE2014) or 750mA (NTE2012, NTE2015) are permissible, making them ideal for driving tungstun filament lamps. The NTE2011 is a general purpose array that may be used with standard bi-polar digital logic using external current limiting, or with most PMOS or CMOS directly. This device is pinned with outputs opposite inputs to facilitate printed wiring board layouts. The NTE2012 is designed for use with 14V to 25V PMOS devices. Each input has a Zener diode and resistor in series to limit the input current to a safe value in that application. The
  • Количество выводов: 16
  • Device Type: Darlington
  • Напряжение питания: 30 В
  • Выходное напряжение: 50 В
  • Выходной ток: 600 мА
  • Напряжение питания максимальное: 5 В
На английском языке: Datasheet NTE2013 - NTE Electronics DARLINGTON ARRAY, NPN, 7, 50 V, DIP
