Datasheet NTE2018 - NTE Electronics Даташит DARLINGTON ARRAY, EIGHT, 50 В, DIP — Даташит
NTE Electronics NTE2018
Наименование модели: NTE2018
Производитель: NTE Electronics
Описание: DARLINGTON ARRAY, EIGHT, 50 В, DIP
data sheetСкачать Data Sheet
NTE2016/NTE2017/NTE2018/NTE2019/NTE2020 Integrated Circuit 8-Channel Darlington Array/Driver
Description: Ideally suited for interfacing between low-level digital logic circuitry and high-power peripheral loads, the NTE2011 through NTE2015 are high-voltage, high-current Darlington arrays in an 18-Lead DIP type package and feature peak load current ratings to 600mA (NTE2016, NTE2019) or 750mA (NTE2017, NTE2018, NTE2020) for each of the eight drivers in each device.
Under the proper conditions, high-power loads up to 4A at 50V (200W at 23% duty cycle) or 3.2A at 95V (304W at 33% duty cycle) can be controlled. Typical loads include relays, solenoids, stepping motors, multiplexed LED and incadescent displays, and heaters. All devices feature open collector outputs and integral diodes for inductive load transient suppression. The NTE2016 is a general purpose array that may be used with standard bi-polar digital logic using external current limiting, or with most PMOS or CMOS directly. This
  • Module Configuration: Eight
  • Collector Emitter Voltage V(br)ceo: 50 В
  • Power Dissipation Pd: 2.25 Вт
  • DC Collector Current: 600 мА
  • DC Current Gain Max (hfe): 1000
  • Рабочий диапазон температрур: -20°C ... +85°C
На английском языке: Datasheet NTE2018 - NTE Electronics DARLINGTON ARRAY, EIGHT, 50 V, DIP
Политика конфиденциальности
