Datasheet NTE2019 - NTE Electronics Даташит DARLINGTON ARRAY, EIGHT, 50 В, DIP — Даташит
Наименование модели: NTE2019
![]() 7 предложений от 6 поставщиков Дискретное устройство, PDIP 50V 0.6A | |||
NTE2019 NTE Electronics | 170 ₽ | ||
NTE2019 | по запросу | ||
NTE2019 NTE Electronics | по запросу | ||
Производитель: NTE Electronics
Описание: DARLINGTON ARRAY, EIGHT, 50 В, DIP
NTE2016/NTE2017/NTE2018/NTE2019/NTE2020 Integrated Circuit 8-Channel Darlington Array/Driver
Description: Ideally suited for interfacing between low-level digital logic circuitry and high-power peripheral loads, the NTE2011 through NTE2015 are high-voltage, high-current Darlington arrays in an 18-Lead DIP type package and feature peak load current ratings to 600mA (NTE2016, NTE2019) or 750mA (NTE2017, NTE2018, NTE2020) for each of the eight drivers in each device.
Under the proper conditions, high-power loads up to 4A at 50V (200W at 23% duty cycle) or 3.2A at 95V (304W at 33% duty cycle) can be controlled. Typical loads include relays, solenoids, stepping motors, multiplexed LED and incadescent displays, and heaters. All devices feature open collector outputs and integral diodes for inductive load transient suppression. The NTE2016 is a general purpose array that may be used with standard bi-polar digital logic using external current limiting, or with most PMOS or CMOS directly. This
- Collector Emitter Voltage V(br)ceo: 50 В
- Power Dissipation Pd: 2.25 Вт
- DC Collector Current: 500 мА
- Рабочий диапазон температрур: -20°C ... +85°C
- Количество выводов: 18
- Continuous Collector Current Ic: 500 мА
