Datasheet NTE916 - NTE Electronics Даташит Транзистор Array ИС — Даташит
NTE Electronics NTE916
Наименование модели: NTE916
Двухполюсный плоскостной транзистор, PDIP NPN 16V 0.1A
NTE916
NTE Electronics
574 ₽
NTE916
NTE Electronics
984 ₽
NTE916BULK
NTE Electronics
NTE916
Производитель: NTE Electronics
Описание: Транзистор Array ИС
data sheetСкачать Data Sheet
NTE916 Integrated Circuit High Current, NPN Transistor Array, Common Emitter
Description: The NTE916 is a high current transistor array in a 16­Lead DIP type package consisting of seven silicon NPN transistors on a common monolithic substrate connected in a common­emitter configuration designed for directly driving seven­segment displays and light­emitting diodes (LED) displays.
This device is also well suited for a variety of other drive applications including relay control and thyristor firing. Features: D Seven Transistors Permit a Wide Range of Applications D High Collector Current: IC = 100mA Max D Low Collector­Emitter Saturation Voltage: VCE(sat) = 400mV Typ @ 50mA Absolute Maximum Ratings: (TA = +25°C unless otherwise specified) Power Dissipation (Total Package), PD . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 750mW Per Transistor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
  • Тип корпуса: 16-DIP
  • Module Configuration: Seven
  • Полярность транзистора: NPN
  • Collector Emitter Voltage V(br)ceo: 16 В
  • Power Dissipation Pd: 750 мВт
  • DC Collector Current: 100 мА
  • DC Current Gain: 40
  • Рабочий диапазон температрур: -55°C ... +125°C
  • Корпус транзистора: DIP
  • Количество выводов: 16
  • SVHC: No SVHC (15-Dec-2010)
  • Количество транзисторов: 7
  • Current Ic Continuous a Max: 100 мА
На английском языке: Datasheet NTE916 - NTE Electronics Transistor Array IC
