Datasheet LM394CH - National Semiconductor Даташит Транзистор PAIR, TO-5-6, 394 — Даташит
Наименование модели: LM394CH
|  Купить LM394CH на РадиоЛоцман.Цены — от 63 до 4 246 ₽ 17 предложений от 15 поставщиков TRANS 2NPN 20V 0.02A TO99-6. Bipolar (BJT) Transistor Array 2 NPN (Dual) 20V 20mA 500mW Through Hole TO-99-6. Transistors - Bipolar... | |||
| LM394CH/NOPB National Semiconductor | от 2 722 ₽ | ||
| LM394CH/NOPB Texas Instruments | 4 246 ₽ | ||
| LM394CH/NOPB Texas Instruments | по запросу | ||
| LM394CH | по запросу | ||
Описание: Транзистор PAIR, TO-5-6, 394
LM194 LM394 Supermatch Pair
December 1994
General Description
The LM194 and LM394 are junction isolated ultra wellmatched monolithic NPN transistor pairs with an order of magnitude improvement in matching over conventional transistor pairs This was accomplished by advanced linear processing and a unique new device structure Electrical characteristics of these devices such as drift versus initial offset voltage noise and the exponential relationship of base-emitter voltage to collector current closely approach those of a theoretical transistor Extrinsic emitter and base resistances are much lower than presently available pairs either monolithic or discrete giving extremely low noise and theoretical operation over a wide current range Most parameters are guaranteed over a current range of 1 mA to 1 mA and 0V up to 40V collector-base voltage ensuring superior performance in nearly all applications To guarantee long term stability of matching parameters intern
- Module Configuration: Dual
- Полярность транзистора: NPN
- Collector Emitter Voltage V(br)ceo: 20 В
- Power Dissipation Pd: 500 мВт
- DC Collector Current: 20 мА
- DC Current Gain: 500
- Рабочий диапазон температрур: -25°C ...+85°C
- Корпус транзистора: TO-5
- Количество выводов: 6
- SVHC: No SVHC (15-Dec-2010)
- Маркировка: LM394CH
- Количество транзисторов: 2
- Тип корпуса: TO-5
- Способ монтажа: Through Hole
- Тип транзистора: General Purpose
- Семейство: 394
- Current Ic Continuous a Max: 20 мА
- IC Generic Number: 394
- Тип входа: Transistor Base
- Количество логических функций: 394
- Выходной ток максимальный: 20 мА
- Выходное напряжение максимальное: 20 В
Дополнительные аксессуары:
- AAVID THERMALLOY - 5F-2
- Dow Corning - 2265931
- Fischer Elektronik - KK 504
- Fischer Elektronik - WLK 5
 Скачать Data Sheet
Скачать Data Sheet
