Datasheet NE5517ANG - ON Semiconductor Даташит ИС, транскондуктивный усилитель, 2 МГц, DIP-16 — Даташит
Наименование модели: NE5517ANG
![]() 11 предложений от 11 поставщиков IC OPAMP TRANSCOND 2 CIRC 16DIP. Transconductance Amplifier 2 Circuit Push-Pull 16-DIP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps... | |||
NE5517ANG ON Semiconductor | 103 ₽ | ||
NE5517ANG ON Semiconductor | по запросу | ||
Производитель: ON Semiconductor
Описание: ИС, транскондуктивный усилитель, 2 МГц, DIP-16
NE5517, NE5517A, AU5517 Dual Operational Transconductance Amplifier
The AU5517 and NE5517 contain two current-controlled transconductance amplifiers, each with a differential input and push-pull output.
The AU5517/NE5517 offers significant design and performance advantages over similar devices for all types of programmable gain applications. Circuit performance is enhanced through the use of linearizing diodes at the inputs which enable a 10 dB signal-to-noise improvement referenced to 0.5% THD. The AU5517/NE5517 is suited for a wide variety of industrial and consumer applications. Constant impedance of the buffers on the chip allow general use of the AU5517/NE5517. These buffers are made of Darlington transistors and a biasing network that virtually eliminate the change of offset voltage due to a burst in the bias current IABC, hence eliminating the audible noise that could otherwise be heard in high quality audio applications.
Features http://onsemi.com MARKING DIAGRAMS
1
SOIC-16 D
- Количество усилителей: 2
- Напряжение питания: 44 В
- Добротность: 2 МГц
- Входное напряжение: ± 5 В
- Диапазон выходных токов: 350 мкА ... 650 мкА
- Скорость нарастания: 50 В/мкс
- Входное сопротивление: 26 кОм
