Datasheet DS90CF388AVJD/NOPB - National Semiconductor Даташит ИС, RECEIVER — Даташит
Наименование модели: DS90CF388AVJD/NOPB
![]() 36 предложений от 16 поставщиков Чип интерфейса, TEXAS INSTRUMENTS DS90CF388AVJD/NOPB LVDS Driver, Dual Pixel, LVDS Receiver, 240mA, -10℃, 70℃, 3V | |||
DS90CF388AVJD/NOPB Texas Instruments | от 161 ₽ | ||
DS90CF388AVJD/NOPB Texas Instruments | от 10 142 ₽ | ||
DS90CF388AVJD/NOPB Texas Instruments | по запросу | ||
Описание: ИС, RECEIVER
DS90C387A/DS90CF388A Dual Pixel LVDS Display Interface / FPD-Link
February 2006
General Description
The DS90C387A/DS90CF388A transmitter/receiver pair is designed to support dual pixel data transmission between Host and Flat Panel Display up to QXGA resolutions.
The transmitter converts 48 bits (Dual Pixel 24-bit color) of CMOS/TTL data and 3 control bits into 8 LVDS (Low Voltage Differential Signalling) data streams. At a maximum dual pixel rate of 112MHz, LVDS data line speed is 784Mbps, providing a total throughput of 5.7Gbps (714 Megabytes per second). The LDI chipset is improved over prior generations of FPDLink devices and offers higher bandwidth support and longer cable drive. To increase bandwidth, the maximum pixel clock rate is increased to 112 MHz and 8 serialized LVDS outputs are provided. Cable drive is enhanced with a user selectable pre-emphasis feature that provides additional output current during tran
- Диапазон напряжения питания: 3 В ... 3.6 В
- Рабочий диапазон температрур: -10°C ... +70°C
- Тип корпуса: TQFP
- Количество выводов: 100
- SVHC: No SVHC (15-Dec-2010)
- Семейство: 90
- Способ монтажа: SMD
- Скорость передачи данных: 784 Mbps
- Интерфейс: LVDS
- Количество приемников: 9
- Propagation Delay: 0.5 нс
- Ток потребления: 185 мА
