Оптопары и оптореле Megawin
Datasheet DS90LV048ATMTC/NOPB - National Semiconductor Даташит ИС, RECEIVER, счетверенный, 400 Mbps, SMD — Даташит
National Semiconductor DS90LV048ATMTC/NOPB
Наименование модели: DS90LV048ATMTC/NOPB
50 предложений от 18 поставщиков
Микросхема LVDS, M-LVDS, ECL, CML, TEXAS INSTRUMENTS DS90LV048ATMTC/NOPB LVDS Driver, Quad CMOS, LVDS Differential Line Receiver, 1.5ns, 15mA, -40℃, 85℃, 3V...
DS90LV048ATMTC/NOPB
83 ₽
DS90LV048ATMTC/NOPB
288 ₽
DS90LV048ATMTC/NOPB
от 396 ₽
Контест
DS90LV048ATMTC/NOPB
Описание: ИС, RECEIVER, счетверенный, 400 Mbps, SMD
data sheetСкачать Data Sheet
DS90LV048A 3V LVDS Quad CMOS Differential Line Receiver
May 2001
General Description
The DS90LV048A is a quad CMOS flow-through differential line receiver designed for applications requiring ultra low power dissipation and high data rates.
The device is designed to support data rates in excess of 400 Mbps (200 MHz) utilizing Low Voltage Differential Signaling (LVDS) technology. The DS90LV048A accepts low voltage (350 mV typical) differential input signals and translates them to 3V CMOS output levels. The receiver supports a TRI-STATE ® function that may be used to multiplex outputs. The receiver also supports open, shorted and terminated (100) input failsafe. The receiver output will be HIGH for all fail-safe conditions. The DS90LV048A has a flow-through pinout for easy PCB layout. The EN and EN* inputs are ANDed together and control the TRI-STATE outputs. The enables are common to all four receivers. The DS90LV048A and companio
  • Диапазон напряжения питания: 3 В ... 3.6 В
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Тип корпуса: TSSOP
  • Количество выводов: 16
  • SVHC: No SVHC (15-Dec-2010)
  • Способ монтажа: SMD
  • Скорость передачи данных: 400 Mbps
  • Интерфейс: LVDS
  • Количество приемников: 4
  • Propagation Delay: 2 нс
  • Ток потребления: 15 мА
Дополнительные аксессуары:
  • Electrolube - SMA10SL
  • Roth Elektronik - RE933-03
  • STANNOL - 574601
На английском языке: Datasheet DS90LV048ATMTC/NOPB - National Semiconductor IC, RECEIVER, QUAD, 400 Mbps, SMD
