Datasheet DS92001TMA/NOPB - National Semiconductor Даташит ИС, RECEIVER — Даташит
Наименование модели: DS92001TMA/NOPB
![]() 41 предложений от 18 поставщиков Интегральные микросхемы Интерфейс - Буферы сигналов, Повторители, Распределители | |||
DS92001TMA/NOPB Texas Instruments | 287 ₽ | ||
DS92001TMA/NOPB Texas Instruments | от 445 ₽ | ||
DS92001TMA/NOPB Texas Instruments | от 836 ₽ | ||
DS92001TMA/NOPB Texas Instruments | по запросу |
Описание: ИС, RECEIVER
DS92001 3.3V B/LVDS-BLVDS Buffer
July 29, 2008
General Description
The DS92001 B/LVDS-BLVDS Buffer takes a BLVDS input signal and provides a BLVDS output signal.
In many large systems, signals are distributed across backplanes. One of the limiting factors for system speed is the "stub length" or the distance between the transmission line and the unterminated receivers on individual cards. Although it is generally recognized that this distance should be as short as possible to maximize system performance, real-world packaging concerns often make it difficult to make the stubs as short as the designer would like. The DS92001 has edge transitions optimized for multidrop backplanes where the switching frequency is in the 200 MHz range or less. The output edge rate is critical in some systems where long stubs may be present, and utilizing a slow transition allows for longer stub lengths. The DS92001, available in the LLP (Leadless Leadframe Package) packag
- Диапазон напряжения питания: 3 В ... 3.6 В
- Рабочий диапазон температрур: -40°C ... +85°C
- Тип корпуса: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Семейство: 92001
- Способ монтажа: SMD
- Скорость передачи данных: 400 Mbps
- Propagation Delay: 1.4 нс
- Ток потребления: 50 мА
