Datasheet DS90CR283MTD/NOPB - National Semiconductor Даташит ИС, передатчик — Даташит
National Semiconductor DS90CR283MTD/NOPB
Наименование модели: DS90CR283MTD/NOPB
Чип интерфейса, LVDS 0.45V 56Pin TSSOP
DS90CR283MTD/NOPB
629 ₽
DS90CR283MTD/NOPB
629 ₽
Hi-Tech Circuit Group
DS90CR283MTD/NOPB
SUV System
DS90CR283MTD/NOPB
Описание: ИС, передатчик
data sheetСкачать Data Sheet
DS90CR283/DS90CR284 28-Bit Channel Link-66 MHz
July 2001
General Description
The DS90CR283 transmitter converts 28 bits of CMOS/TTL data into four LVDS (Low Voltage Differential Signaling) data streams.
A phase-locked transmit clock is transmitted in parallel with the data streams over a fifth LVDS link. Every cycle of the transmit clock 28 bits of input data are sampled and transmitted. The DS90CR284 receiver converts the LVDS data streams back into 28 bits of CMOS/TTL data. At a transmit clock frequency of 66 MHz, 28 bits of TTL data are transmitted at a rate of 462 Mbps per LVDS data channel. Using a 66 MHz clock, the data throughput is 1.848 Gbit/s (231 Mbytes/s). The multiplexing of the data lines provides a substantial cable reduction. Long distance parallel single-ended buses typically require a ground wire per active signal (and have very limited noise rejection capability). Thus, for a 28-bit wide data bus and one clock, up to 5
  • Рабочий диапазон температрур: -10°C ... +70°C
  • Количество выводов: 56
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: TSSOP
  • Семейство: 90
  • Способ монтажа: SMD
  • Интерфейс: LVDS
  • Propagation Delay: 0.75 нс
  • Ток потребления: 70 мА
  • Диапазон напряжения питания: 4.75 В ... 5.25 В
На английском языке: Datasheet DS90CR283MTD/NOPB - National Semiconductor IC, TRANSMITTER
