Datasheet Texas Instruments BQ24030RHLR — Даташит
СерияBQ24030
МодельBQ24030RHLR
Литий-ионное зарядное устройство с двумя входами и динамическим управлением питанием, выходное напряжение регулируется до 6 В, Vbat 4,2 В, 20-VQFN от -40 до 85
bq2403x Single-Chip Charge and System Power-path Management IC (bqTINYв„ў) datasheet
PDF, 1.4 Мб, Версия: I, Файл опубликован: 30 дек 2014
Pin20
Package TypeRHL
Industry STD TermVQFN
JEDEC CodeR-PQFP-N
Package QTY3000
МаркировкаANB
Width (мм)3.5
Length (мм)4.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Absolute Vin (safety rating)(Max)(18 В
Battery Charge Voltage(Max)4.2 В
Battery Charge Voltage(Min)4.2 В
Cell ChemistryLi-Ion/Li-Polymer
Charge Current(Max)1.5 A
Control InterfaceStandalone (RC-Settable)
Control TopologyLinear
Number of Series Cells1
Operating Vin(Max)16 В
Operating Vin(Min)4.35 В
Package GroupVQFN
Package Size: mm2:W x L20VQFN: 16 mm2: 3.5 x 4.5(VQFN) PKG
Special FeaturesIntegrated LDO,Power Path,Temp Monitoring (Thermistor Pin)
USB FeatureN/A
  • Evaluation Modules & Boards: BQ24030EVM
    BQ24030 Evaluation Module
  • Single-chip bq2403x power-path manager charges battery while powering system
    PDF, 175 Кб, Файл опубликован: 17 июл 2006
  • Adjustable/Variable Clock Timer For bq24030/2/5 Li-Ion One-Cell Battery Chargers
    PDF, 151 Кб, Файл опубликован: 13 сен 2005
    The bq2403x Battery Charger and Dynamic Power Path Management (DPPM) IC is a highly integrated IC which minimizes the required wall adapter size by reducing the battery charging current during peak current demands by the system. Typically, a 5-hour charge timer is used to limit the charge time on the battery as a safety feature. Because the charging current can be reduced at any time for any durat
  • Dynamic Power Path Management Simplifies Battery Charging from Solar Panels
    PDF, 666 Кб, Файл опубликован: 17 окт 2006
    The Texas Instruments bq2403x family of linear charge regulators were originally designed to charge single-cell Li-ion batteries from an AC adapter or USB port. However, these ICs also lend themselves well to applications powered by solar panels.
  • Dynamic Power-Path Mgmt & Dynamic Power Mgmt
    PDF, 96 Кб, Файл опубликован: 2 янв 2007
    Dynamic power-path management (DPPM) and dynamic power management (DPM) are two similar types of integrated power management ICs that combine the task of charging a single-cell Li-ion battery and powering the system. Both topologies reduce the battery charging current to give the system priority when the adaptor has reached its output current rating. The bq2403x family and TPS65800 IC use the DPP
Серия: BQ24030 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24030RHLR
