Datasheet Texas Instruments BQ24050DSQT — Даташит
СерияBQ24050
МодельBQ24050DSQT
Зарядное устройство для одноэлементных литий-ионных аккумуляторов, 1 А, с автоматическим определением переменного тока/USB.
bq2405x 1-A, Single-Cell Li-Ion and Li-Pol Battery Charger With Automatic Adaptor and USB Detection datasheet
PDF, 2.2 Мб, Версия: C, Файл опубликован: 11 дек 2014
| Линейный 10-WSON
Pin10
Package TypeDSQ
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY250
CarrierSMALL T&R
МаркировкаCVC
Width (мм)2
Length (мм)2
Thickness (мм).75
Pitch (мм).4
Max Height (мм).8
Absolute Vin (safety rating)(Max)(30 В
Battery Charge Voltage(Max)4.2 В
Battery Charge Voltage(Min)4.2 В
Cell ChemistryLi-Ion/Li-Polymer
Charge Current(Max)1 A
Control InterfaceStandalone (RC-Settable)
Control TopologyLinear
Number of Series Cells1
Operating Vin(Max)28 В
Operating Vin(Min)3.5 В
Package GroupWSON
Package Size: mm2:W x LSee datasheet (WSON) PKG
Special FeaturesJEITA BAT Temp Monitoring (Thermistor Pin),Temp Monitoring (Thermistor Pin),Thermal Regulation,Vin DPM (OK for Solar Power Source)
USB FeatureN/A
  • Evaluation Modules & Boards: BQ24050EVM
    BQ24050 Evaluation Module: 0.8-A, Single-Input, Single-Cell Li-Ion Battery Charger
  • Automatic AC/USB Detection in bq24050/2/5 Using D+/D- pins
    PDF, 134 Кб, Файл опубликован: 25 янв 2010
    Modern day electronic devices, such as cell phones and MP3 players, can usually be powered with either an adapter or USB source through a single input connector using a mini USB cable. For a simple charger, without separate power paths for the system and the battery, the system (including the device transceiver) is powered directly from the battery. If the battery is deeply discharged, it has to
  • Charging a three-cell nickel-based battery pack with a Li-Ion charger
    PDF, 127 Кб, Файл опубликован: 26 апр 2012
  • Li-ion battery-charger solutions for JEITA compliance
    PDF, 506 Кб, Файл опубликован: 29 янв 2010
  • Selecting the Best bq2404x/5x/9x Single Cell Battery Charger for your Applicatio
    PDF, 38 Кб, Файл опубликован: 29 ноя 2012
  • 2Q 2012 Issue Analog Applications Journal
    PDF, 2.4 Мб, Файл опубликован: 26 апр 2012
  • Q1 2010 Issue Analog Applications Journal
    PDF, 2.6 Мб, Файл опубликован: 29 янв 2010
Серия: BQ24050 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24050DSQT
