Datasheet Texas Instruments TPS65052RSMT — Даташит
СерияTPS65050
МодельTPS65052RSMT
6-канальная ИС управления питанием (PMIC) с 2 DC/DC, 4 LDO, размером 4x4 мм QFN 32-VQFN от -40 до 85
TPS6505x 6-Channel Power-Management IC With Two Step-Down Converters and Four Low-Input Voltage LDOs datasheet
PDF, 1.6 Мб, Версия: C, Файл опубликован: 21 фев 2017
Pin3232
Package TypeRSMRSM
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY250250
CarrierSMALL T&RSMALL T&R
МаркировкаTPS65052
Width (мм)44
Length (мм)44
Thickness (мм).9.9
Pitch (мм).4.4
Max Height (мм)11
Iout(Max)0.6 A
Iq(Typ)2.4 мА
LDO4
Package GroupVQFN
Package Size: mm2:W x L32VQFN: 16 mm2: 4 x 4(VQFN) PKG
Processor NameS3C2410/2/3
Processor SupplierSamsung
Regulated Outputs6
Step-Down DC/DC Converter2
Switching Frequency(Max)2250 kHz
Vin(Max)6.5 В
Vin(Min)1.5 В
Vout(Max)6 В
Vout(Min)0.6 В
  • Evaluation Modules & Boards: TPS65050EVM-195
    TPS65050 6-channel Power Mgmt IC with 2 DC/DCs Evaluation Module Board
  • Evaluation Modules & Boards: TPS65054EVM-195
    TPS65054 6-channel Power Management IC (PMIC) with 2 DC/DCs Evaluation Module Board
  • Evaluation Modules & Boards: TPS65056EVM-195
    TPS65056 Evaluation Module
  • Evaluation Modules & Boards: TPS65052EVM-195
    TPS65052 6-channel Power Management IC (PMIC) with 2 DC/DCs Evaluation Module Board
  • Evaluation Modules & Boards: TPS65051EVM-195
    TPS65051 6-channel Power Management IC with 2 DC/DCs Evaluation Module Board
  • TPS6505x Design Guide
    PDF, 116 Кб, Файл опубликован: 10 апр 2015
  • TPS6505x Device Comparison (Rev. B)
    PDF, 81 Кб, Версия: B, Файл опубликован: 25 фев 2009
    This application report presents an overview of the differences among the TPS65050, TPS65051, TPS65052, TPS65053, TPS65054, TPS65055, TPS65056, and TPS65058 power management ICs. It can assist design engineers in selecting the most suitable IC for their applications.
  • Optimizing Resistor Dividers at a Comparator (Rev. A)
    PDF, 120 Кб, Версия: A, Файл опубликован: 3 июн 2013
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
  • Semiconductors > Power Management > Power Management Multi-Channel IC (PMIC) Solutions
На английском языке: Datasheet Texas Instruments TPS65052RSMT
