Datasheet Texas Instruments BQ24103RHLR — Даташит
СерияBQ24103
МодельBQ24103RHLR
Автономное синхронное импульсное литий-ионное зарядное устройство с полевым транзистором 2 А в QFN-20, 1- или 2-элементный 20-VQFN от -40 до 85
bq241xx Synchronous Switched-Mode, Li-Ion and Li-Polymer Charge-Management IC With Integrated Power FETs (bqSWITCHERв„ў) datasheet
PDF, 1.5 Мб, Версия: P, Файл опубликован: 30 ноя 2015
Pin20
Package TypeRHL
Industry STD TermVQFN
JEDEC CodeR-PQFP-N
Package QTY3000
МаркировкаCID
Width (мм)3.5
Length (мм)4.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Absolute Vin (safety rating)(Max)(20 В
Battery Charge Voltage(Max)4.2,8.4 В
Battery Charge Voltage(Min)4.2,8.4 В
Cell ChemistryLi-Ion/Li-Polymer
Charge Current(Max)2 A
Control InterfaceStandalone (RC-Settable)
Control TopologySwitch-Mode Buck
Number of Series Cells1,2
Operating Vin(Max)16 В
Operating Vin(Min)4.35 В
Package GroupVQFN
Package Size: mm2:W x L20VQFN: 16 mm2: 3.5 x 4.5(VQFN) PKG
Special FeaturesIntegrated FET,Temp Monitoring (Thermistor Pin)
USB FeatureN/A
  • Evaluation Modules & Boards: BQ24103EVM
    BQ24103 Evaluation Module
  • Using USB Power Supply With Standalone Chargers for Two-Cell Li Ion Batteries
    PDF, 317 Кб, Файл опубликован: 22 ноя 2013
  • Li-ion switching charger integrates power FETs
    PDF, 142 Кб, Файл опубликован: 10 окт 2005
  • bq24103/13/23/33 Comparison
    PDF, 38 Кб, Файл опубликован: 12 авг 2011
    This application report presents an overview of the differences among the bq24103, bq24113, bq24123 and bq24133. It assists design engineers in selecting the most suitable charger for their applications.
  • Power Dissipation Analysis & Circuit Design for Sync Switching Battery Charger
    PDF, 402 Кб, Файл опубликован: 31 май 2005
    The bqSWITCHER(TM) (bq24100/03/05/08/13/15) is a highly integrated, switch-mode, Li-ion and Li-polymer battery charger IC. With two power MOSFETs, the gate drivers, and the controller fully integrated in the chip, the circuit design as well as the PCB layout has been appreciably simplified. However, it is still important to have a good understanding of the charger circuit design, layout principles
  • Implementations of Battery Charger and Power-Path Mgmt System Using bq241xx
    PDF, 752 Кб, Файл опубликован: 6 июн 2006
    This application report presents four system topologies that can be used to fully implement a portable power management system solution using the bqSWITCHERв„ў. Test results and the advantages and issues of each topology are discussed.
  • Drive High Current LEDs
    PDF, 437 Кб, Файл опубликован: 25 янв 2007
    This application report presents high-current LED driving requirements that use the TI integrated boost converter IC TPS6106x and integrated buck converter IC bqSWITCHERв„ў (bq2410x/11x/12x). Step-by-step design procedures, measurement results, and two dimming methods are provided and discussed.
Серия: BQ24103 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24103RHLR
