Datasheet Texas Instruments BQ24120RHLTG4 — Даташит
СерияBQ24120
МодельBQ24120RHLTG4
Синхронное импульсное зарядное устройство для 1-элементной литий-ионной батареи с полевым транзистором 2 А, улучшенными характеристиками электромагнитных помех 20-VQFN от -40 до 85
bq2412x Single-Chip Switched-Mode, Li-Ion, and Li-Polymer Charge-Management IC With Enhanced EMI Performance (bqSWITCHERв„ў) datasheet
PDF, 2.1 Мб, Версия: H, Файл опубликован: 30 ноя 2015
Pin20
Package TypeRHL
Industry STD TermVQFN
JEDEC CodeR-PQFP-N
Width (мм)3.5
Length (мм)4.5
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
# Series Cells1
Absolute Vin (safety rating)(Max)((V))20
Approx. Price (US$)2.00 | 1ku
Battery Charge Voltage(Max)(V)4.2
Battery Charge Voltage(Min)(V)4.2
Cell ChemistryLi-Ion/Li-Polymer
Charge Current(Max)(A)2
Control InterfaceStandalone (RC-Settable)
Control TopologySwitch-Mode Buck
Operating Vin(Max)(V)16
Operating Vin(Min)(V)4.35
Package GroupVQFN
Package Size: mm2:W x L (PKG)20VQFN: 16 mm2: 3.5 x 4.5(VQFN)
Special FeaturesIntegrated FET
Temp Monitoring (Thermistor Pin)
USB FeatureN/A
RoHSНе совместим
  • Implementations of Battery Charger and Power-Path Mgmt System Using bq241xx
    PDF, 752 Кб, Файл опубликован: 6 июн 2006
    This application report presents four system topologies that can be used to fully implement a portable power management system solution using the bqSWITCHERв„ў. Test results and the advantages and issues of each topology are discussed.
  • Drive High Current LEDs
    PDF, 437 Кб, Файл опубликован: 25 янв 2007
    This application report presents high-current LED driving requirements that use the TI integrated boost converter IC TPS6106x and integrated buck converter IC bqSWITCHERв„ў (bq2410x/11x/12x). Step-by-step design procedures, measurement results, and two dimming methods are provided and discussed.
Серия: BQ24120 (4)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24120RHLTG4
