Datasheet Texas Instruments BQ24450DW — Даташит
СерияBQ24450
МодельBQ24450DW
Встроенный контроллер заряда свинцово-кислотных аккумуляторов 16-SOIC
Integrated Charge Controller for Lead-Acid Batteries.. datasheet
PDF, 885 Кб, Версия: C, Файл опубликован: 1 фев 2012
30 предложений от 17 поставщиков
Микросхема Чип управления батареи, TEXAS INSTRUMENTS BQ24450DW Battery Charger for 1 Cell of Lead Acid battery, 40V input, 40mA charge, SOIC-16...
BQ24450DW
718 ₽
BQ24450DW
1 122 ₽
Элитан
BQ24450DW
2 057 ₽
BQ24450DW
Pin16
Package TypeDW
Package QTY40
МаркировкаBQ24450DW
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Absolute Vin (safety rating)(Max)(40 В
Battery Charge Voltage(Max)20 В
Cell ChemistryLead Acid
Charge Current(Max)10 A
Control InterfaceStandalone (RC-Settable)
Control TopologyLinear
Number of Series Cells1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16
Operating Vin(Max)40 В
Operating Vin(Min)5 В
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Special FeaturesN/A
USB FeatureN/A
  • Evaluation Modules & Boards: BQ24450EVM-691
    Evaluation Module for BQ24450 Integrated Charge Controller for Lead-Acid Batteries
  • U-104 Improved Charging Methods for Lead-Acid Batteries Using the UC3906
    PDF, 331 Кб, Файл опубликован: 5 сен 1999
    This application note describes the operation and application of the UC3906 sealed lead-acid battery-charger IC. Several charging circuits using this IC are described, along with expected improvements in battery performance. This note also discusses uses for the many auxiliary functions of the part.
  • U-131 Simple Switchmode Lead-Acid Battery Charger
    PDF, 206 Кб, Файл опубликован: 5 сен 1999
    Lead-acid batteries are finding considerable use as bothprimary and backup power sources. For complete batteryutilization the charger circuit must charge the batteryto full capacity while minimizing over-charging forextended battery life. Since battery capacity varies withtemperature the charger must vary the amount of chargewith temperature to realize maximum capacity and life.Si
Серия: BQ24450 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24450DW
