Datasheet Texas Instruments BQ24702PWG4 — Даташит
СерияBQ24702
МодельBQ24702PWG4
Многохимический контроллер заряда аккумулятора и переключатель мощности системы 24-TSSOP от -40 до 125
Multichemistry Battery Charger Controller & System Power Selector datasheet
PDF, 880 Кб, Версия: E, Файл опубликован: 18 окт 2007
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY60
Маркировка24702PW
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Absolute Vin (safety rating)(Max)(30 В
Battery Charge Voltage(Max)16.8 В
Battery Charge Voltage(Min)8.4 В
Cell ChemistryLi-Ion/Li-Polymer
Charge Current(Max)2 A
Control InterfaceStandalone (RC-Settable)
Control TopologySwitch-Mode Buck
Number of Series Cells2,3,4
Operating Vin(Max)28 В
Operating Vin(Min)7 В
Package GroupTSSOP
Package Size: mm2:W x L24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
Special FeaturesPower Path
USB FeatureN/A
  • How to Review a Multicell Switching Charger Schematic
    PDF, 196 Кб, Файл опубликован: 21 сен 2011
    This application report provides a checklist for reviewing a switching charger schematic and explains each item in the list.
  • Dynamic Power-Path Mgmt & Dynamic Power Mgmt
    PDF, 96 Кб, Файл опубликован: 2 янв 2007
    Dynamic power-path management (DPPM) and dynamic power management (DPM) are two similar types of integrated power management ICs that combine the task of charging a single-cell Li-ion battery and powering the system. Both topologies reduce the battery charging current to give the system priority when the adaptor has reached its output current rating. The bq2403x family and TPS65800 IC use the DPP
Серия: BQ24702 (4)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ24702PWG4
