Datasheet ISL6252AHAZ - Intersil Даташит Зарядное устройство батареи аккумуляторов контроллер, QSOP24 — Даташит
Intersil ISL6252AHAZ
Наименование модели: ISL6252AHAZ
16 предложений от 16 поставщиков
Микросхема Чип управления батареи, Battery Charger Li-Ion/Li-Pol 4.2V 24Pin QSOP W
ISL6252AHAZ-T
Renesas
78 ₽
TradeElectronics
ISL6252AHAZ
Intersil
ISL6252AHAZ
727GS
ISL6252AHAZ-T
Renesas
Производитель: Intersil
Описание: Зарядное устройство батареи аккумуляторов контроллер, QSOP24
data sheetСкачать Data Sheet
ISL6252, ISL6252A
Data Sheet July 19, 2007 FN6498.1
Highly Integrated Battery Charger Controller for Notebook Computers
The ISL6252, ISL6252A is a highly integrated battery charger controller for Li-Ion/Li-Ion polymer batteries.
High Efficiency is achieved by a synchronous buck topology. The low side MOSFET emulates a diode at light loads to improve the light load efficiency and prevent system bus boosting. The constant output voltage can be selected for 2, 3 and 4 series Li-Ion cells with 0.5% accuracy over-temperature. It can also be programmed between 4.2V + 5%/cell and 4.2V - 5%/cell to optimize battery capacity. When supplying the load and battery charger simultaneously, the input current limit for the AC adapter is programmable to within 3% accuracy to avoid overloading the AC adapter, and to allow the system to make efficient use of available adapter power for charging. It also has a wide range of programmable charging current. The ISL6252, ISL6252A provides outputs that are
  • Battery Type: Li-Ion / Li-Polymer
  • Входное напряжение: 25 В
  • Battery Charge Voltage: 5.075 В
  • Battery IC Case Style: QSOP
  • Количество выводов: 24
  • Number of Series Cells: 4
  • Рабочий диапазон температрур: -10°C ... +100°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: QSOP
  • Семейство: 6252
  • Battery Management Function: Charger, Status Monitor
  • Входное напряжение максимальное: 25 В
  • Выходное напряжение максимальное: 17.64 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 7 В ... 25 В
Дополнительные аксессуары:
  • Roth Elektronik - RE932-07
  • STANNOL - 574601
  • STANNOL - 631954
На английском языке: Datasheet ISL6252AHAZ - Intersil BATTERY CHARGER CONTROLLER, QSOP24
