Datasheet ISL9203CRZ-TR5220 - Intersil Даташит Зарядное устройство, POLYMER батарея, DFN-10 — Даташит
Intersil ISL9203CRZ-TR5220
Наименование модели: ISL9203CRZ-TR5220
Микросхема Чип управления батареи, Battery Charger Li-Ion/Li-Pol Packs 1600mA 4.2V 10Pin DFN EP T/R
ISL9203CRZ-TR5220
Intersil
64 ₽
ISL9203CRZ-TR5220
Intersil
772 ₽
ISL9203CRZ-TR5220
Intersil
772 ₽
727GS
ISL9203CRZ-TR5220
Intersil
от 847 ₽
Производитель: Intersil
Описание: Зарядное устройство, POLYMER батарея, DFN-10
data sheetСкачать Data Sheet
ISL9203R5220
Data Sheet January 3, 2006 FN9242.1
Li-ion/Li Polymer Battery Charger
The ISL9203R5220 is an integrated single-cell Li-ion or Li-polymer battery charger capable of operating with an input voltage as low as 2.4V.
This charger is designed to work with various types of AC adapters. The ISL9203R5220 operates as a linear charger when the AC adapter is a voltage source. The battery is charged in a CC/CV (constant current/constant voltage) profile. The charge current is programmable with an external resistor up to 1.5A. The ISL9203R5220 can also work with a currentlimited adapter to minimize the thermal dissipation, in which case the ISL9203R5220 combines the benefits of both a linear charger and a pulse charger. The ISL9203R5220 features charge current thermal foldback to guarantee safe operation when the printed circuit board is space limited for thermal dissipation. Additional features include preconditioning of an over-discharged battery and thermally enhanced DFN package
  • Battery Type: Li-Ion / Li-Polymer
  • Входное напряжение: 6.5 В
  • Battery Charge Voltage: 4.2 В
  • Charge Current Max: 1.5 А
  • Battery IC Case Style: DFN
  • Количество выводов: 10
  • Number of Series Cells: 1
  • Рабочий диапазон температрур: -20°C ... +70°C
  • SVHC: No SVHC (20-Jun-2011)
  • Семейство: 9203
  • Battery Management Function: Charger
  • Входное напряжение максимальное: 6.5 В
  • Выходное напряжение максимальное: 4.242 В
  • Тип корпуса: DFN
  • Способ монтажа: SMD
  • Напряжения питания Vcc: 7 В
  • Диапазон напряжения питания: 4.3 В ... 6.5 В
ISL9203CRZTR5220, ISL9203CRZ TR5220
На английском языке: Datasheet ISL9203CRZ-TR5220 - Intersil CHARGER, POLYMER BATTERY, DFN-10
