Datasheet LM3658SD-A - National Semiconductor Даташит BATT зарядное устройство, LI ион USB/AC, LLP-10 — Даташит
Наименование модели: LM3658SD-A
![]() 35 предложений от 16 поставщиков Микросхема Чип управления батареи, TEXAS INSTRUMENTS LM3658SD-A/NOPB Battery Charger for 1 Cell of Li-Ion, Li-Pol battery, 6V input, 4.2V / 1000mA... | |||
LM3658SD-A/NOPB Texas Instruments | от 48 ₽ | ||
LM3658SD-A/NOPB Texas Instruments | 49 ₽ | ||
LM3658SD-A Texas Instruments | 147 ₽ | ||
LM3658SD-A/NOPB Texas Instruments | от 163 ₽ |
Описание: BATT зарядное устройство, LI ион USB/AC, LLP-10
LM3658 Dual Source USB/AC Li Chemistry Charger IC for Portable Applications
November 2006
General Description
The LM3658 is a single chip charger IC designed for handheld applications.
It can safely charge and maintain a single cell Li-Ion/Polymer battery operating from an AC wall adapter or USB power source. Input power source selection of USB/AC is automatic. With both power sources present, the AC power source has priority. Charge current is programmed through an external resistor when operating from an AC wall adapter allowing charge currents from 50 mA to 1000 mA. When the battery is charged using USB power, charge currents of 100 mA or 500 mA are pin-selectable. The termination voltage is controlled to within ±0.35% of 4.2V. The LM3658 requires few external components and integrates internal power FETs, reverse current protection and current sensing. The internal power FETs are thermally regulated to ob
- Battery Type: Li-Ion / Li-Polymer
- Входное напряжение: 6 В
- Battery Charge Voltage: 4.2 В
- Charge Current Max: 1000 мА
- Battery IC Case Style: LLP
- Количество выводов: 10
- Number of Series Cells: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (19-Dec-2011)
- Семейство: 3658
- Battery Management Function: Charger
- Входное напряжение максимальное: 6 В
- Выходное напряжение максимальное: 4.2 В
- Тип корпуса: LLP
- Способ монтажа: SMD
- Диапазон напряжения питания: 4.3 В ... 6 В
LM3658SDA, LM3658SD A
