Datasheet LT1511CSW - Linear Technology Даташит ИС, зарядное устройство батареи аккумуляторов 3 А, SMD, SOIC24 — Даташит
Наименование модели: LT1511CSW
![]() 34 предложений от 24 поставщиков Микросхема Чип управления батареи, Battery Charger Li-Ion/NiCD/NiMH 3000mA 1V to 20V 24Pin SOIC W | |||
LT1511CSW#TRPBF Analog Devices | 297 ₽ | ||
LT1511CSW#PBF Analog Devices | 451 ₽ | ||
LT1511CSW | 1 397 ₽ | ||
LT1511CSW#TRPBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, зарядное устройство батареи аккумуляторов 3 А, SMD, SOIC24
FEATURES
s
LT1511 Constant-Current/ Constant-Voltage 3A Battery Charger with Input Current Limiting DESCRIPTIO
The LT®1511 current mode PWM battery charger is the simplest, most efficient solution to fast charge modern rechargeable batteries including lithium-ion (Li-Ion), nickelmetal-hydride (NiMH) and nickel-cadmium (NiCd) that require constant-current and/or constant-voltage charging.
The internal switch is capable of delivering 3A* DC current (4A peak current). Full-charging current can be programmed by resistors or a DAC to within 5%. With 0.5% reference voltage accuracy, the LT1511 meets the critical constant-voltage charging requirement for Li-Ion cells. A third control loop is provided to regulate the current drawn from the AC adapter. This allows simultaneous operation of the equipment and battery charging without overloading the adapter. Charging current is reduced to keep the adapter current within specified levels. The LT1511 can charge batteries ranging from 1V to 20V. Gr
- Battery Type: Li-Ion / NiCd / NiMH
- Входное напряжение: 25 В
- Battery Charge Voltage: 20 В
- Charge Current Max: 3 А
- Battery IC Case Style: SOIC
- Количество выводов: 24
- Рабочий диапазон температрур: 0°C ... +70°C
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Семейство: 1511
- Battery Management Function: Charger
- Входное напряжение максимальное: 28 В
- Выходной ток максимальный: 4 А
- Выходное напряжение максимальное: 20 В
- Способ монтажа: SMD
- Напряжения питания Vcc: 30 В
- Выходное напряжение: 57 В
- Диапазон напряжения питания: 8 В ... 28 В
Дополнительные аксессуары:
- Electrolube - HTS35SL
- Fischer Elektronik - ICK SMD A 10 SA
- Roth Elektronik - RE932-07
- STANNOL - 631954
