Datasheet LT1512CS8 - Linear Technology Даташит Зарядное устройство батареи аккумуляторов, SMD, 1512, SOIC8 — Даташит
Наименование модели: LT1512CS8
Купить LT1512CS8 на РадиоЛоцман.Цены — от 170 до 1 146 ₽43 предложений от 22 поставщиков Микросхема Чип управления батареи, LINEAR TECHNOLOGY LT1512CS8#PBF Battery Charger for 4 Cells of Li-Ion battery, 25V input, 30V / 1.5A charge,... | |||
| LT1512CS8#PBF Linear Technology | 292 ₽ | ||
| LT1512CS8 Linear Technology | 316 ₽ | ||
| LT1512CS8#PBF | от 997 ₽ | ||
| LT1512CS8 Analog Devices | 1 146 ₽ | ||
Производитель: Linear Technology
Описание: Зарядное устройство батареи аккумуляторов, SMD, 1512, SOIC8
LT1512 SEPIC Constant-Current/ Constant-Voltage Battery Charger
FEATURES
s s s
DESCRIPTION
The LT ®1512 is a 500kHz current mode switching regulator specially configured to create a constant-current/ constant-voltage battery charger.
In addition to the usual voltage feedback node, it has a current sense feedback circuit for accurately controlling output current of a flyback or SEPIC (Single-Ended Primary Inductance Converter) topology charger. These topologies allow the current sense circuit to be ground referred and completely separated from the battery itself, simplifying battery switching and system grounding problems. In addition, these topologies allow charging even when the input voltage is lower than the battery voltage. Maximum switch current on the LT1512 is 1.5A. This allows battery charging currents up to 1A for a single lithium-ion cell. Accuracy of 1% in constant-voltage mode is perfect for lithium battery applications. Charging current can be easily programmed for all ba
- Battery Type: Li-Ion
- Входное напряжение: 25 В
- Battery Charge Voltage: 30 В
- Charge Current Max: 1.5 А
- Battery IC Case Style: SOIC
- Количество выводов: 8
- Number of Series Cells: 1
- Рабочий диапазон температрур: 0°C ... +70°C
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Семейство: 1512
- Battery Management Function: Charger
- IC Generic Number: 1512
- Входное напряжение максимальное: 30 В
- Количество логических функций: 1512
- Выходной ток максимальный: 1.5 А
- Выходное напряжение максимальное: 30 В
- Способ монтажа: SMD
- Тактовая частота: 500 кГц
- Выходное напряжение: 40 В
- Power Supply IC Type: Battery charger
- Тип стабилизатора: Fixed
- Диапазон напряжения питания: 2.4 В ... 30 В
Дополнительные аксессуары:
- Dow Corning - 2265931
- Fischer Elektronik - ICK SMD A 5 SA
- Fischer Elektronik - WLK 5
- Roth Elektronik - RE932-01
