Datasheet LT1513-2CR - Linear Technology Даташит BATT зарядное устройство, SEPIC CONST, 7D2PAK — Даташит
Linear Technology LT1513-2CR
Наименование модели: LT1513-2CR
Микросхема Чип управления батареи, Battery Charger Lead-Acid/Li-Ion/NiCD/NiMH 2000mA 20V 8Pin(7+Tab) DDPAK
LT1513-2CR
309 ₽
LT1513-2CR
LT1513-2CR
LT1513-2CR
Производитель: Linear Technology
Описание: BATT зарядное устройство, SEPIC CONST, 7D2PAK
data sheetСкачать Data Sheet
LT1513/LT1513-2 SEPIC Constant- or Programmable-Current/ Constant-Voltage Battery Charger
FEATURES
s s s
DESCRIPTION
The LT ®1513 is a 500kHz current mode switching regulator specially configured to create a constant- or programmable-current/constant-voltage battery charger.
In addition to the usual voltage feedback node, it has a current sense feedback circuit for accurately controlling output current of a flyback or SEPIC (Single-Ended Primary Inductance Converter) topology charger. These topologies allow the current sense circuit to be ground referred and completely separated from the battery itself, simplifying battery switching and system grounding problems. In addition, these topologies allow charging even when the input voltage is lower than the battery voltage. The LT1513 can also drive a CCFL Royer converter with high efficiency in floating or grounded mode. Maximum switch current on the LT1513 is 3A. This allows battery charging currents up to 2A for a single lithium-ion ce
  • Battery Type: Lead Acid / Li-Ion / NiCd / NiMH
  • Входное напряжение: 25 В
  • Battery Charge Voltage: 20 В
  • Battery IC Case Style: D2PAK
  • Количество выводов: 7
  • Рабочий диапазон температрур: 0°C ... +125°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: D2PAK
  • Семейство: 513
  • Battery Management Function: Charger
  • Входное напряжение максимальное: 25 В
  • Выходное напряжение максимальное: 20 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 2.7 В ... 25 В
Дополнительные аксессуары:
  • Fischer Elektronik - FK 244 08 D2 PAK
  • Fischer Elektronik - FK 244 13 D2 PAK
  • Fischer Elektronik - WLK 5
LT15132CR, LT1513 2CR
На английском языке: Datasheet LT1513-2CR - Linear Technology BATT CHARGER, SEPIC CONST, 7D2PAK
