Datasheet LT3652EMSE - Linear Technology Даташит ИС, зарядное устройство батареи аккумуляторов, 2 А, MSOP-12 — Даташит
Наименование модели: LT3652EMSE
36 предложений от 17 поставщиков Микросхема Чип управления батареи, Battery Charger Li-Ion 2000mA 4.2V 12Pin MSOP EP T/R | |||
LT3652EMSE Analog Devices | от 390 ₽ | ||
LT3652EMSE#PBF Analog Devices | от 899 ₽ | ||
LT3652EMSE#PBF Linear Technology | по запросу | ||
LT3652EMSE Analog Devices | по запросу |
Производитель: Linear Technology
Описание: ИС, зарядное устройство батареи аккумуляторов, 2 А, MSOP-12
LT3652 Power Tracking 2A Battery Charger for Solar Power FEATURES
n n n n n
DESCRIPTION
The LT®3652 is a complete monolithic step-down battery charger that operates over a 4.95V to 32V input voltage range.
The LT3652 provides a constant-current/ constant-voltage charge characteristic, with maximum charge current externally programmable up to 2A. The charger employs a 3.3V float voltage feedback reference, so any desired battery float voltage up to 14.4V can be programmed with a resistor divider. The LT3652 employs an input voltage regulation loop, which reduces charge current if the input voltage falls below a programmed level, set with a resistor divider. When the LT3652 is powered by a solar panel, the input regulation loop is used to maintain the panel at peak output power. The LT3652 can be configured to terminate charging when charge current falls below 1/10 of the programmed maximum (C/10). Once charging is terminated, the LT3652 enters a low-current (85A) standby mode. An auto-
- Battery Type: Li-Ion, Li Polymer, NiCd, NiMH
- Входное напряжение: 7.5 В
- Battery Charge Voltage: 4.2 В
- Charge Current Max: 2 А
- Battery IC Case Style: MSOP
- Количество выводов: 12
- Number of Series Cells: 1
Дополнительные аксессуары:
- WUERTH ELEKTRONIK - 7447779122
