Datasheet LT3652HVEMSE - Linear Technology Даташит ИС, зарядное устройство батареи аккумуляторов, LITHIUM, 2 А, MSOP12 — Даташит
Наименование модели: LT3652HVEMSE
30 предложений от 15 поставщиков Микросхема Чип управления батареи, LINEAR TECHNOLOGY LT3652HVEMSE#PBF Battery Charger for 4 Cells of Lead Acid, LiFePO4, Li-Ion, Li-Pol, 34Vin, 18V/2A charge,... | |||
LT3652HVEMSE#TRPBF Analog Devices | от 147 ₽ | ||
LT3652HVEMSE#TRPBF Linear Technology | 304 ₽ | ||
LT3652HVEMSE#PBF Linear Technology | 442 ₽ | ||
LT3652HVEMSE#PBF Analog Devices | от 1 002 ₽ |
Производитель: Linear Technology
Описание: ИС, зарядное устройство батареи аккумуляторов, LITHIUM, 2 А, MSOP12
LT3652HV Power Tracking 2A Battery Charger FEATURES
n n n n n
DESCRIPTION
The LT®3652HV is a complete monolithic step-down battery charger that operates over a 4.95V to 34V input range.
The LT3652HV provides a constant-current/constant-voltage charge characteristic, with maximum charge current externally programmable up to 2A. The charger employs a 3.3V float voltage feedback reference, so any desired battery float voltage up to 18V can be programmed with a resistor divider. The LT3652HV employs an input voltage regulation loop, which reduces charge current if the input voltage falls below a programmed level, set with a resistor divider. When the LT3652HV is powered by a solar panel, the input regulation loop is used to maintain the panel at peak output power. The LT3652HV can be configured to terminate charging when charge current falls below 1/10 of the programmed maximum (C/10). Once charging is terminated, the LT3652HV enters a low-current (85A) standby mode. An auto-recharge feat
- Battery Type: Li-Ion, Li-Polymer
- Входное напряжение: 34 В
- Battery Charge Voltage: 18 В
- Charge Current Max: 2 А
- Battery IC Case Style: MSOP
- Количество выводов: 12
- Number of Series Cells: 6
Дополнительные аксессуары:
- Linear Technology - DC1568A.
- WUERTH ELEKTRONIK - 7447779122
