Datasheet LTC1960CG - Linear Technology Даташит Зарядное устройство батареи аккумуляторов, SMD, SSOP36, 1960 — Даташит
Наименование модели: LTC1960CG
38 предложений от 20 поставщиков Микросхема Чип управления батареи, LINEAR TECHNOLOGY LTC1960CG#PBF Battery Charger for 2 Cells of Li-Ion, Li-Pol, NiCd, NiMH battery, 28V input, 4.1A... | |||
LTC1960CG#PBF Linear Technology | 86 ₽ | ||
LTC1960CG#PBF Analog Devices | 464 ₽ | ||
LTC1960CG#TRPBF Analog Devices | от 2 029 ₽ | ||
LTC1960CG TRPBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: Зарядное устройство батареи аккумуляторов, SMD, SSOP36, 1960
LTC1960 Dual Battery Charger/ Selector with SPI Interface
FEATURES
DESCRIPTIO
Complete Dual-Battery Charger/Selector System Serial SPI Interface Allows External µC Control and Monitoring Simultaneous Dual-Battery Discharge Extends Run Time by Typically 10% Simultaneous Dual-Battery Charging Reduces Charging Time by Up to 50% Automatic PowerPathTM Switching in <10µs Prevents Power Interruption Circuit Breaker Protects Against Overcurrent Faults 5% Accurate Adapter Current Limit Maximizes Charging Rate* 95% Efficient Synchronous Buck Charger Charger Has Low 0.5V Dropout Voltage No Audible Noise Generation, Even with Ceramic Capacitors 11-Bit VDAC Delivers 0.8% Voltage Accuracy 10-Bit IDAC Delivers 5% Current Accuracy VIN Up to 32V; VBATT Up to 28V Available in 5mm Ч 7mm 38-Pin QFN and 36-Pin Narrow SSOP Packages
The LTC®1960 is a highly-integrated battery charger and selector intended for portable products using dual smart batteries.
A serial SPI interface allows an exte
- Battery Type: Li-Ion / Li-Polymer / NiCd / NiMH
- Входное напряжение: 28 В
- Battery Charge Voltage: 28 В
- Charge Current Max: 4.1 А
- Battery IC Case Style: SSOP
- Количество выводов: 36
- Рабочий диапазон температрур: 0°C ... +70°C
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SSOP
- Семейство: 1960
- Battery Management Function: Charger
- Control Interface: Serial, SPI
- Входное напряжение максимальное: 32 В
- Выходное напряжение максимальное: 28 В
- Способ монтажа: SMD
- Напряжения питания Vcc: 32 В
- Выходное напряжение: 28 В
- Диапазон напряжения питания: 6 В ... 28 В
Дополнительные аксессуары:
- Electrolube - HTS35SL
- Fischer Elektronik - ICK SMD A 8 SA
- Roth Elektronik - RE931-06
- STANNOL - 574601
