Datasheet LTC1980EGN - Linear Technology Даташит BATT зарядное устройство & постоянный ток постоянный ток CONV, 24SSOP — Даташит
Linear Technology LTC1980EGN
Наименование модели: LTC1980EGN
35 предложений от 18 поставщиков
Switching Battery Charger Lead-Acid/Li-Ion/Li-Pol/NiCd/NiMH 2000mA 4.1V/4.2V/8.2V/8.4V 24-Pin SSOP N Tube
LTC1980EGN#PBF
288 ₽
LTC1980EGN#TR
346 ₽
LTC1980EGN#PBF
698 ₽
ЭИК
LTC1980EGN#PBF
от 1 123 ₽
Производитель: Linear Technology
Описание: BATT зарядное устройство & постоянный ток постоянный ток CONV, 24SSOP
data sheetСкачать Data Sheet
LTC1980 Combination Battery Charger and DC/DC Converter
FEATURES
DESCRIPTIO
Single Controller IC Includes Battery Charger Plus DC/DC Converter Wall Adapter Voltage May be Above or Below Battery Voltage LDO Controller Allows Simultaneous Charging and Regulating from Wall Adapter Input Standalone Li-Ion Battery Charger Including Charge Termination, Overvoltage Protection, Shorted-Cell Detection and Battery Recharge Selectable 4.1V, 4.2V, 8.2V and 8.4V Float Voltages Simple NiMH and NiCd Battery Charger Pin Programmable Regulator Burst Mode® Operation and Shutdown for High Efficiency High Efficiency Current Mode 300kHz PWM Reduced Component Architecture Undervoltage Protection and Soft-Start Ensures Start-Up with Current Limited Wall Adapter Small 24-Pin SSOP Package
The LTC®1980 integrates PWM power control for charging a battery and converting the battery voltage to a regulated output or simultaneously charging the battery while powering a system load from an unregulated
  • Battery Type: Li-Ion / NiCd / NiMH
  • Входное напряжение: 10 В
  • Battery Charge Voltage: 10 В
  • Charge Current Max: 2 А
  • Battery IC Case Style: SSOP
  • Количество выводов: 24
  • Number of Series Cells: 2
  • Рабочий диапазон температрур: -40°C ...
    +85°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SSOP
  • Семейство: 1980
  • Battery Management Function: Charger
  • Входное напряжение максимальное: 12 В
  • Выходное напряжение максимальное: 8.4 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 2.85 В ... 10 В
Дополнительные аксессуары:
  • Roth Elektronik - RE931-04
На английском языке: Datasheet LTC1980EGN - Linear Technology BATT CHARGER & DC DC CONV, 24SSOP
