Datasheet LTC3559EUD - Linear Technology Даташит ИС, BATT зарядное устройство, W/BUCK REG, 16QFN — Даташит
Linear Technology LTC3559EUD
Наименование модели: LTC3559EUD
36 предложений от 22 поставщиков
Микросхема Чип управления батареи, LINEAR TECHNOLOGY LTC3559EUD#PBF Battery Charger for 1 Cell of Li-Ion, Li-Pol battery, 5.5V input, 4.2V/500mA charge, QFN-16...
LTC3559EUD#PBF
139 ₽
Hi-Tech Circuit Group
LTC3559EUD#PBF
LTC3559EUD#PBF
ТаймЧипс
LTC3559EUD#TRPBF
Производитель: Linear Technology
Описание: ИС, BATT зарядное устройство, W/BUCK REG, 16QFN
data sheetСкачать Data Sheet
FEATURES
Battery Charger n Standalone USB Charger n Up to 950mA Charge Current Programmable via Single Resistor n HPWR Input Selects 20% or 100% of Programmed Charge Current n NTC Input for Temperature Qualified Charging n Internal Timer Termination n Bad Battery Detection n CHRG Indicates C/10 or Timeout Buck Regulators n 400mA Output Current n 2.25MHz Constant Frequency Operation n Zero Current in Shutdown n Low Noise Pulse Skip Operation or Power Saving Burst Mode Operation n Low No-Load Quiescent Current: 35A n Available in a Low Profile Thermally Enhanced 16-Lead 3mm Ч 3mm QFN Package
LTC3559/LTC3559-1 Linear USB Battery Charger with Dual Buck Regulators DESCRIPTION
The LTC®3559/LTC3559-1 are USB battery chargers with dual high efficiency buck regulators.
The parts are ideally suited to power single-cell Li-Ion/Polymer based handheld applications needing multiple supply rails. Battery charge current is programmed via the PROG pin and the HPWR pin, with capability up to 950mA at t
  • Battery Type: Li-Ion
  • Входное напряжение: 5.5 В
  • Battery Charge Voltage: 4.2 В
  • Charge Current Max: 950 мА
  • Battery IC Case Style: QFN
  • Количество выводов: 16
  • Number of Series Cells: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: QFN
  • Семейство: 3559
  • Battery Management Function: Charger
  • Выходное напряжение максимальное: 4.2 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 4.3 В ... 5.5 В
На английском языке: Datasheet LTC3559EUD - Linear Technology IC, BATT CHARGER, W/BUCK REG, 16QFN
