Datasheet LTC4001EUF - Linear Technology Даташит ИС LI-ION зарядное устройство, SYNCHRO BUCK, 2 А — Даташит
Linear Technology LTC4001EUF
Наименование модели: LTC4001EUF
40 предложений от 22 поставщиков
Микросхема Чип управления батареи, LINEAR TECHNOLOGY LTC4001EUF#PBF Battery Charger for 1 Cell of Li-Ion battery, 5.5V input, 4.2V/2.2A charge, QFN-16
LTC4001EUF#PBF
167 ₽
Зенер
Россия и страны ТС
LTC4001EUF-1#PBF
от 270 ₽
LTC4001EUF#TRPBF
515 ₽
ТаймЧипс
LTC4001EUF
Производитель: Linear Technology
Описание: ИС LI-ION зарядное устройство, SYNCHRO BUCK, 2 А
data sheetСкачать Data Sheet
LTC4001 2A Synchronous Buck Li-Ion Charger
FEATURES
DESCRIPTIO
Low Power Dissipation 2A Maximum Charge Current No External MOSFETs, Sense Resistor or Blocking Diode Required Remote Sensing at Battery Terminals Programmable Charge Termination Timer Preset 4.2V Float Voltage with ±0.5% Accuracy Programmable Charge Current Detection/Termination Automatic Recharge Thermistor Input for Temperature Qualified Charging Compatible with Current Limited Wall Adapters Low Profile 16-Lead (4mm Ч 4mm) QFN Package
The LTC®4001 is a 2A Li-Ion battery charger intended for 5V wall adapters.
It utilizes a 1.5MHz synchronous buck converter topology to reduce power dissipation during charging. Low power dissipation, an internal MOSFET and sense resistor allow a physically small charger that can be embedded in a wide range of handheld applications. The LTC4001 includes complete charge termination circuitry, automatic recharge and a ±1% 4.2V float voltage. Input short-circuit protection is inc
  • Battery Type: Li-Ion
  • Входное напряжение: 5.5 В
  • Battery Charge Voltage: 4.2 В
  • Charge Current Max: 2 А
  • Battery IC Case Style: QFN
  • Количество выводов: 16
  • Number of Series Cells: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: QFN
  • Семейство: 4001
  • Battery Management Function: Charger
  • Входное напряжение максимальное: 5.5 В
  • Выходное напряжение максимальное: 4.242 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 4 В ... 5.5 В
Дополнительные аксессуары:
  • BONKOTE - BON102
  • CHEMTRONICS - CW8400
  • Electrolube - SMA10SL
На английском языке: Datasheet LTC4001EUF - Linear Technology IC LI-ION CHARGER, SYNCHRO BUCK, 2 A
