Заказные клавиатуры Accord по вашему ТЗ
Datasheet LTC4006EGN-2 - Linear Technology Даташит ИС, BATT зарядное устройство, LI ON, 4 А, 16SSOP — Даташит
Linear Technology LTC4006EGN-2
Наименование модели: LTC4006EGN-2
Производитель: Linear Technology
Описание: ИС, BATT зарядное устройство, LI ON, 4 А, 16SSOP
data sheetСкачать Data Sheet
FEATURES
LTC4006 4A, High Efficiency, Standalone Li-Ion Battery Charger DESCRIPTIO
The LTC®4006 is a complete constant-current/constantvoltage charger controller for 2-, 3- or 4-cell lithium batteries in a small package using few external components.
The PWM controller is a synchronous, quasi-constant frequency, constant off-time architecture that will not generate audible noise even when using ceramic capacitors. The LTC4006 is available in 8.4V, 12.6V and 16.8V versions with ±0.8% voltage accuracy. Charging current is programmable with a single sense resistor to ±4% typical accuracy. Charging current can be monitored as a representative voltage at the IMON pin. A timer, programmed by an external resistor, sets the total charge time or is reset to 25% of total charge time after C/10 charging current is reached. Charging automatically resumes when the cell voltage falls below 3.9V/cell. Fully discharged cells are automatically trickle charged at 10% of the programmed cur
  • Battery Type: Li-Ion
  • Входное напряжение: 28 В
  • Battery Charge Voltage: 11.5 В
  • Charge Current Max: 4 А
  • Battery IC Case Style: SSOP
  • Количество выводов: 16
  • Number of Series Cells: 4
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SSOP
  • Семейство: 4006
  • Battery Management Function: Charger
  • Входное напряжение максимальное: 28 В
  • Выходное напряжение максимальное: 12.6 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 6 В ... 28 В
Дополнительные аксессуары:
  • Roth Elektronik - RE931-02
LTC4006EGN2, LTC4006EGN 2
На английском языке: Datasheet LTC4006EGN-2 - Linear Technology IC, BATT CHARGER, LI ON, 4 A, 16SSOP
Политика конфиденциальности
