Datasheet LTC4009CUF - Linear Technology Даташит ИС, зарядное устройство, MULTI CHEMISTRY, 20QFN — Даташит
Наименование модели: LTC4009CUF
Купить LTC4009CUF на РадиоЛоцман.Цены — от 129 до 1 168 ₽41 предложений от 24 поставщиков Микросхема Чип управления батареи, LINEAR TECHNOLOGY LTC4009CUF#PBF Battery Charger for 6 Cells of Li-Ion, Li-Pol, NiCd, NiMH battery, 28V input, 28V/4A... | |||
| LTC4009CUF-2#PBF Analog Devices | 141 ₽ | ||
| LTC4009CUF#PBF Linear Technology | 204 ₽ | ||
| LTC4009CUF#TRPBF | 348 ₽ | ||
| LTC4009CUF#PBF Analog Devices | от 858 ₽ | ||
Производитель: Linear Technology
Описание: ИС, зарядное устройство, MULTI CHEMISTRY, 20QFN
Your Electronic Engineering Resource
LTC4009 - High Efficiency, Multi-Chemistry Battery Charger
General Description:
The LTC4009 is a constant-current/constant-voltage battery charger controller.
It uses a synchronous quasiconstant frequency PWM control architecture that will not generate audible noise with ceramic bulk capacitors. Charge current is set by the combination of external sense, input and programming resistors. With no built-in termination, the LTC4009 family charges a wide range of batteries under external control. The LTC4009 features a fully adjustable output voltage, while the LTC4009-1 and LTC4009-2 can be pin-programmed for lithium-ion/polymer battery packs of 1-, 2-, 3- or 4-series cells. The LTC4009-1 provides output voltage of 4.1V/cell, and the LTC4009-2 is a 4.2V/cell version. The device includes AC adapter input current limiting which maximizes the charge rate for a fixed input power level. An external sense resistor programs the input current limit, and th
- Battery Type: Universal
- Входное напряжение: 28 В
- Battery Charge Voltage: 12 В
- Charge Current Max: 4 А
- Battery IC Case Style: QFN
- Количество выводов: 20
- Number of Series Cells: 6
- Рабочий диапазон температрур: 0°C ... +85°C
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: QFN
- Семейство: 4009
- Battery Management Function: Charger
- Входное напряжение максимальное: 28 В
- Выходное напряжение максимальное: 28 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 6 В ... 28 В
