Datasheet LTC4060EFE - Linear Technology Даташит ИС, зарядное устройство батареи аккумуляторов, SMD, TSSOP16 — Даташит
Наименование модели: LTC4060EFE
40 предложений от 20 поставщиков Микросхема Чип управления батареи, LINEAR TECHNOLOGY LTC4060EFE#PBF Battery Charger for 4 Cells of NiCd, NiMH battery, 10V input, 2.8V / 2A... | |||
LTC4060EFE#TRPBF Analog Devices | 298 ₽ | ||
LTC4060EFE#TRPBF Linear Technology | 384 ₽ | ||
LTC4060EFE Analog Devices | 1 363 ₽ | ||
LTC4060EFE#TRPBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, зарядное устройство батареи аккумуляторов, SMD, TSSOP16
LTC4060 Standalone Linear NiMH/NiCd Fast Battery Charger
FEATURES
DESCRIPTIO
Complete Fast Charger Controller for Single, 2-, 3- or 4-Series Cell NiMH/NiCd Batteries No Firmware or Microcontroller Required Termination by V, Maximum Voltage or Maximum Time No Sense Resistor or Blocking Diode Required Automatic Recharge Keeps Batteries Charged Programmable Fast Charge Current: 0.4A to 2A Accurate Charge Current: ±5% at 2A Fast Charge Current Programmable Beyond 2A with External Sense Resistor Automatic Detection of Battery Precharge for Heavily Discharged Batteries Optional Temperature Qualified Charging Charge and AC Present Status Outputs Can Drive LED Automatic Sleep Mode with Input Supply Removal Negligible Battery Drain in Sleep Mode: <1µA Manual Shutdown Input Supply Range: 4.5V to 10V Available in 16-Lead DFN and TSSOP Packages
The LTC®4060 is a complete fast charging system for NiMH or NiCd batteries.
Just a few external components are needed to design a sta
- Battery Type: NiCd / NiMH
- Входное напряжение: 10 В
- Battery Charge Voltage: 2.8 В
- Charge Current Max: 2 А
- Battery IC Case Style: TSSOP
- Количество выводов: 16
- Number of Series Cells: 2
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: TSSOP
- Семейство: 4060
- Battery Management Function: Charger
- Входное напряжение максимальное: 10 В
- Выходной ток максимальный: -2.2 А
- Способ монтажа: SMD
- Напряжения питания Vcc: 11 В
- Выходное напряжение: 11.3 В
- Диапазон напряжения питания: 4.5 В ... 10 В
Дополнительные аксессуары:
- Electrolube - HTS35SL
- Fischer Elektronik - ICK SMD A 10 SA
- Roth Elektronik - RE933-03
- STANNOL - 631954
