Datasheet LTC4061EDD-4.4 - Linear Technology Даташит ИС, BATT зарядное устройство, LI ON, 1 А, 10DFN — Даташит
Наименование модели: LTC4061EDD-4.4
![]() 22 предложений от 17 поставщиков Linear Battery Charger Li-Ion/Li-Pol 1000mA 4.375V 10-Pin DFN EP Tube / IC BATT CHARGER LI-ION 10-DFN | |||
LTC4061EDD-4.4#PBF Analog Devices | 570 ₽ | ||
LTC4061EDD-4.4#PBF Analog Devices | от 758 ₽ | ||
LTC4061EDD-4.4 Analog Devices | по запросу | ||
LTC4061EDD-4.4 Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, BATT зарядное устройство, LI ON, 1 А, 10DFN
LTC4061 Standalone Linear Li-Ion Battery Charger with Thermistor Input
Charge Current Programmable Up to 1A Charges Single-Cell Li-Ion Batteries Directly from USB Port Preset Charge Voltage with ±0.35% Accuracy Thermistor Input for Temperature Qualified Charging Input Supply Present Logic Output Thermal Regulation Maximizes Charge Rate Without Risk of Overheating Programmable Charge Current Detection/ Termination Programmable Charge Termination Timer Smart Pulsing Error Feature SmartStartTM Prolongs Battery Life 20µA Charger Quiescent Current in Shutdown Available in a Low Profile (0.75mm) 10-Lead (3mm Ч 3mm) DFN Package
The LTC®4061 is a full-featured, flexible, standalone linear charger for single-cell Lithium-Ion batteries.
It is capable of operating within USB power specifications. Both programmable time and programmable current based termination schemes are available. Furthermore, the CHRG open-drain status pin can be programmed to indicate the battery charge sta
- Battery Type: Li-Ion / Li-Polymer
- Входное напряжение: 8 В
- Battery Charge Voltage: 4.4 В
- Charge Current Max: 840 мА
- Battery IC Case Style: DFN
- Количество выводов: 10
- Number of Series Cells: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DFN
- Семейство: 4061
- Battery Management Function: Charger
- Входное напряжение максимальное: 8 В
- Выходное напряжение максимальное: 4.2 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 4.3 В ... 8 В
LTC4061EDD4.4, LTC4061EDD 4.4
