Datasheet LTC4064EMSE - Linear Technology Даташит BATT зарядное устройство, MONOLITHIC, 10MSOP — Даташит
Linear Technology LTC4064EMSE
Наименование модели: LTC4064EMSE
39 предложений от 21 поставщиков
Микросхема Чип управления батареи, LINEAR TECHNOLOGY LTC4064EMSE#PBF Battery Charger for 1 Cell of Li-Ion battery, 6.5V input, 4.04V/535mA charge, MSOP-10
LTC4064EMSE#TR
168 ₽
LTC4064EMSE TRPBF
727GS
LTC4064EMSE
TradeElectronics
LTC4064EMSE#TR
Производитель: Linear Technology
Описание: BATT зарядное устройство, MONOLITHIC, 10MSOP
data sheetСкачать Data Sheet
LTC4064 Monolithic Linear Charger for Back-Up Li-Ion Batteries
FEATURES
DESCRIPTIO
Preset 4V Charge Voltage with 1% Accuracy Prolongs 4.2V Li-Ion Battery Lifetime Automatic Recharge Thermal Regulation Maximizes Charging Rate without Risk of Overheating* No MOSFET, Sense Resistor or Blocking Diode Required Programmable Charge Termination Timer Thermistor Input for Temperature Qualified Charging Programmable Charge Current with 7% Accuracy C/10 Charge Current Detection Output 25µA Supply Current in Shutdown Mode Charge Current Monitor Useful for Gas Gauging* Charges Directly from USB Port Tiny Thermally Enhanced 10-pin MSOP Package
The LTC4064 is a standalone linear charger optimized for prolonging the life of 1-cell Li-ion batteries in battery backup applications.
By charging to a float voltage of 4V instead of 4.2V or 4.1V, the LTC4064 decelerates the aging process and capacity degradation when the battery is unused for long periods of time but must be in a ready state
  • Battery Type: Li-Ion
  • Входное напряжение: 6.5 В
  • Battery Charge Voltage: 4 В
  • Charge Current Max: 535 мА
  • Battery IC Case Style: MSOP
  • Количество выводов: 10
  • Number of Series Cells: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: MSOP
  • Семейство: 4064
  • Battery Management Function: Charger
  • Входное напряжение максимальное: 6.5 В
  • Выходное напряжение максимальное: 4 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 4.25 В ... 6.5 В
Дополнительные аксессуары:
  • Roth Elektronik - RE904
На английском языке: Datasheet LTC4064EMSE - Linear Technology BATT CHARGER, MONOLITHIC, 10MSOP
