Datasheet LTC4076EDD - Linear Technology Даташит BATT зарядное устройство, LI ON, сдвоенный, 10DFN — Даташит
Наименование модели: LTC4076EDD
![]() 26 предложений от 17 поставщиков Микросхема Чип управления батареи, Battery Charger Li-Ion 800mA 4.2V 10Pin DFN EP | |||
LTC4076EDD Analog Devices | 145 ₽ | ||
LTC4076EDD Linear Technology | 185 ₽ | ||
LTC4076EDD#PBF Analog Devices | 357 ₽ | ||
LTC4076EDD#TR Linear Technology | по запросу |
Производитель: Linear Technology
Описание: BATT зарядное устройство, LI ON, сдвоенный, 10DFN
LTC4076 Dual Input Standalone Li-Ion Battery Charger
Charges Single-Cell Li-Ion Batteries from Wall Adapter and USB Inputs Automatic Input Power Detection and Selection Charge Current Programmable up to 950mA from Wall Adapter Input C/X Charge Current Termination Thermal Regulation Maximizes Charge Rate Without Risk of Overheating* Preset Charge Voltage with ±0.6% Accuracy 18µA USB Suspend Current in Shutdown Power Present Status Output Charge Status Output Automatic Recharge Available in a Thermally Enhanced, Low Profile (0.75mm) 10-Lead (3mm Ч 3mm) DFN Package The LTC®4076 is a standalone linear charger that is capable of charging a single-cell Li-Ion battery from both wall adapter and USB inputs.
The charger can detect power at the inputs and automatically select the appropriate power source for charging. No external sense resistor or blocking diode is required for charging due to the internal MOSFET architecture. Internal thermal feedback regulates the battery charge current to mai
- Battery Type: Li-Ion
- Входное напряжение: 8 В
- Battery Charge Voltage: 4.2 В
- Charge Current Max: 950 мА
- Battery IC Case Style: DFN
- Количество выводов: 10
- Number of Series Cells: 1
- Рабочий диапазон температрур: -40°C ... +85°C
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DFN
- Семейство: 4076
- Battery Management Function: Charger
- Входное напряжение максимальное: 8 В
- Выходное напряжение максимальное: 4.2 В
- Способ монтажа: SMD
- Диапазон напряжения питания: 4.3 В ... 8 В
