Datasheet LTC4077EDD - Linear Technology Даташит ИС LI-ION зарядное устройство, сдвоенный, STANDALONE — Даташит
Linear Technology LTC4077EDD
Наименование модели: LTC4077EDD
17 предложений от 16 поставщиков
Linear Battery Charger Li-Ion/Li-Pol 950mA 4.2V 10-Pin DFN EP Tube / IC CHARG BATT LI-ON USB 10DFN
LTC4077EDD#PBF
от 229 ₽
LTC4077EDD#TRPBF
259 ₽
LTC4077EDD#PBF
1 203 ₽
TradeElectronics
LTC4077EDD#PBF
Производитель: Linear Technology
Описание: ИС LI-ION зарядное устройство, сдвоенный, STANDALONE
data sheetСкачать Data Sheet
LTC4077 Dual Input Standalone Li-Ion Battery Charger
Charges Single-Cell Li-Ion Batteries from Wall Adapter and USB Inputs Automatic Input Power Detection and Selection Charge Current Programmable up to 950mA from Wall Adapter Input C/10 Charge Current Termination Thermal Regulation Maximizes Charge Rate Without Risk of Overheating* Preset Charge Voltage with ±0.6% Accuracy 18µA USB Suspend Current in Shutdown Power Present Status Output Charge Status Output Automatic Recharge Available in a Thermally Enhanced, Low Profile (0.75mm) 10-Lead (3mm Ч 3mm) DFN Package The LTC®4077 is a standalone linear charger that is capable of charging a single-cell Li-Ion battery from both wall adapter and USB inputs.
The charger can detect power at the inputs and automatically select the appropriate power source for charging. No external sense resistor or blocking diode is required for charging due to the internal MOSFET architecture. Internal thermal feedback regulates the battery charge current to ma
  • Battery Type: Li-Ion
  • Входное напряжение: 8 В
  • Battery Charge Voltage: 4.2 В
  • Charge Current Max: 950 мА
  • Battery IC Case Style: DFN
  • Количество выводов: 11
  • Number of Series Cells: 1
  • Рабочий диапазон температрур: -40°C ... +85°C
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: DFN
  • Семейство: 4077
  • Battery Management Function: Charger
  • Входное напряжение максимальное: 8 В
  • Выходное напряжение максимальное: 4.24 В
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 4.3 В ... 8 В
Дополнительные аксессуары:
  • BONKOTE - BON102
  • CHEMTRONICS - CW8400
  • Electrolube - SMA10SL
На английском языке: Datasheet LTC4077EDD - Linear Technology IC LI-ION CHARGER, DUAL, STANDALONE
